Author Topic: Choke cable install problem on my 78 CB550  (Read 2103 times)
Offline Leoh21
« on: March 26, 2012, 02:14:36 PM »
Im having trouble installing the choke cable to the carb. The cable was on the bike but it did not come installed on the carb linkage.
Can someone provide pictures of their choke cable set up and routing of the cable? I been looking and looking but I havent had any luck.
Thanks in advance!
Offline Leoh21
Re: Choke cable install problem on my 78 CB550
« Reply #1 on: March 27, 2012, 09:38:14 AM »
I have been tinckering around with the cable but I cant figure out how its supposed to be installed.
Offline Tews19
  • I am no
« Reply #2 on: March 28, 2012, 09:05:17 AM »
First pic shows the choke cable attached.
Second pic shows the screw. You slide the the cable through there and tighten screw.
Last is where the choke pull gets attached. Left side top bolt of triple.
If you need anymore pics let me know
1970 Honda CB750 survivor.
Offline Leoh21
« Reply #3 on: March 28, 2012, 12:33:09 PM »
Thanks so much Tews19!
I cant wait to get home and install it correctly
Btw - its really difficult to push or pull on the choke knob knob while its not its not installed. Is that normal?
Offline Tews19
  • I am no
« Reply #4 on: March 28, 2012, 12:56:06 PM »
Sounds weird, maybe it is attached.. I know they can be stiff.
BTW, before you tighten the screw, make sure you have the cable attached, once attached then tighten.
Offline Leoh21
« Reply #5 on: March 28, 2012, 02:38:30 PM »
No its not attached. It was removed from the bike.
 Thanks for the Tips!
« Reply #6 on: March 28, 2012, 03:03:42 PM »
At the base of the choke knob is a tension/friction adjust, which tends to hold it in place during warm up.
Offline Leoh21
« Reply #7 on: March 29, 2012, 07:57:48 AM »
Thanks for all the advice.
I was working on installing the choke but Im missing the screw that holds the choke (like the second pic that Tews19 shows).
