Author Topic: Sportster Tank??  (Read 3830 times)
Offline 75 super sport
Sportster Tank??
« on: March 26, 2012, 03:49:39 PM »
Has anyone installed a sportster tank from tcbroschoppers on a cb750? Just wondering if the petcock location will work or if i would have to modify it at all. Thanks in the advance for the advice.
"Smoke em if ya got em"
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Sportster Tank??
« Reply #1 on: March 26, 2012, 04:39:42 PM »
Yes, the petcock on the Sportster is on the right rear (early) and will just clear the frame rail.  Of course, the type and position of the mounting will determine exact placement.  I like the "King" Sportster tanks for the extra fuel for the not so thrifty CB750
Offline danfr
    • Apollo Motorcycles
« Reply #2 on: March 26, 2012, 04:43:02 PM »
anyone have a photo of a cb750 with a sportster tank? sounds like it could be amazing.
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
« Reply #3 on: March 26, 2012, 04:46:05 PM »
I actually like the idea of the king sportster tank. So that tank will fit on the cb750 without modification?
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: March 26, 2012, 04:50:25 PM »
Mounts are completely different.  Google "Honda Bobber" images.  It is a common look.
Offline jamesb
« Reply #5 on: March 26, 2012, 07:45:40 PM »
here is mine although it's a aftermarket frame this is a frisco style tank. the petcocks where moved to the back the filler tube was moved towards the front.and the tunnel was filled in.so you can get more fuel out of a tank of gas. these style of tanks where started by the hells angles back in the day.also the frames where modified (choppers) to so the fuel would automaticly go to the back of the tank. you might want to look into the the frisco style tanks they also come in the king sporty make sure you look at the ones with a shallow tunnel. mines inch so it sits on top of the frame.
« Reply #6 on: March 26, 2012, 08:09:02 PM »
 James that thing needs low tunnel mounting.. look better methinks..
« Reply #7 on: March 26, 2012, 10:48:15 PM »
@JamesB... thanks for sharing, it always good to see different styles. I want a new tank for the Cb i just bought and found one on tcbroschoppers.com called the sportster tank and its listed for the cb750. Like the style, just need to figure out what modifications are needed..if any.
Offline Obsidus
« Reply #8 on: March 26, 2012, 11:08:31 PM »
This one is my baby. It has a sporty tank.
