Author Topic: rear brake light options  (Read 1360 times)
Offline famoussas1
« on: March 27, 2012, 05:38:15 PM »
I know its probably not the safest bet, the larger the brake light lens the better someone will see it, well hopefully.  I want to make the rear of my 550 a little more sleek.  I've been reading the posts on LED upgrades, and just wondering the most straightforward way to make my brake light a little brighter and maybe a little more stylish that the stock lens.  Any ideas or what has anyone done that is relatively inexpensive and effective as well?
Or should I just keep it stock (and simple).
http://www.ebay.com/itm/Motorcycle-cat-eye-LED-brake-tail-light-Harley-KTM-Honda-Suzuki-Yamaha-CB-450-/330683084914?pt=Motorcycles_Parts_Accessories&hash=item4cfe3f7072&vxp=mtr#ht_2236wt_1270
Offline nayto550
Re: rear brake light options
« Reply #1 on: March 27, 2012, 06:24:36 PM »
The tail light on my 550F in my avatar pic to the left is a trailer light I picked up off the clearance rack at Lowe's for about $5.
Oh, and it is BRIGHT!!
*edit*  Here's a bigger version of the picture:
« Last Edit: March 27, 2012, 06:28:14 PM by nayto550 »
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline MOtub
« Reply #2 on: March 27, 2012, 07:37:52 PM »
How about a light from an older CB500 or CB750? They're smaller and neater looking, and mount right onto your bracket. Here's a picture of one I have, but haven't installed yet on my 550:
76 CB400F
74 CB550
73 CL125S
Offline WhyNot2
  • I'm finally an
« Reply #3 on: March 28, 2012, 04:04:59 AM »
Here's mine.......................................
Offline SOHC Digger
  • I'm not an
« Reply #4 on: March 28, 2012, 06:07:19 AM »
I'm a big believer in the blue dots!  I know they may be illegal in some states, but I would risk getting a ticket for them any day.  The purplish hugh they give off stands out from all the other taillights and really makes the guy behind you take notice.  I've installed them on ALL my bikes!
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: March 28, 2012, 12:16:23 PM »
I like the shape of mine. I shall be installing a second bulb in it shortly.
Offline INSANE REINDEER
« Reply #6 on: March 28, 2012, 06:55:51 PM »
I have been looking to change mine. After completely re doing my bike the part I hate the most is the tail light/tag section. I want to change that so much. I think you should NOT keep the stock one. They look awful IMO.
Offline Danno
« Reply #7 on: March 28, 2012, 11:56:28 PM »
i put two front turn signals in place of my rear now they light up when the brakes come on or when turning I used red bulbs but you can also use red leds on one end only of your bike if you have an electronic flasher unit you can use leds on both ends if you remove the sounder out of the flasher circuit or add resisters to the lines feeding the led bulbs otherwise the flasher won't have enough amperage flowing through it to flash
Offline Dimitri13
  • 1974 CB550K
« Reply #8 on: March 29, 2012, 12:23:07 AM »
I really like this idea. I pull small trailers a lot but I never thought of using a trailer light on a bike.
Offline SHORTROUND
« Reply #9 on: March 29, 2012, 05:46:21 AM »
Here's a couple I have used
ACE hardware $7
EBAY $15
Advanced Auto Parts $4 each then rewired with LEDs $15
2 1/2 inch merker light rewired with LEDs $20
