Author Topic: NGK D8EA vs D9EA  (Read 12732 times)
Offline Johnie
NGK D8EA vs D9EA
« on: March 29, 2012, 02:26:44 PM »
What is the difference between the 2 plugs? Just the heat range? The reason I ask is I got a box of 10 D9EA for $10 before I realized I have been using the D8EA. Can I run the 9's in the CB750 or would I expect problems.
« Last Edit: March 29, 2012, 02:36:30 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Grey
Re: NGK D8EA vs D9EA
« Reply #1 on: March 29, 2012, 02:34:49 PM »
They are the next stage colder plug. Good for hot weather or running hard for the most part. Stick a set in. If they don't foul then your good to go. If you know someone with a modified motor sell the plugs to them.
Offline grcamna2
« Reply #2 on: March 29, 2012, 02:37:43 PM »
The D8EA are stock plugs for you're CB750..D9EA's are one step colder for running it flat out..or w/ aftermarket high energy coils.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: March 29, 2012, 02:42:14 PM »
They're one step colder than the stock plugs and will tend to foul out under regular street use.
Offline Kevin D
  • SE Michigan
« Reply #4 on: March 29, 2012, 02:53:59 PM »
Johnie  - not that you are asking, but I followed a Hondaman tip and have been happy with my Denso's:
http://www.sparkplugs.com/results_appOther.asp?otherMotiveID=58433&mfid=3
I have a coffee can full of slightly fouled NGK's, just one set of Densos for, I dont know, 3-4 years maybe 10000? miles
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline octagon
« Reply #5 on: March 29, 2012, 07:20:56 PM »
another vote for densos.
this is a little slack, but i found a set in good shape in a parts bike, and did a search and found hondaman's recommendation. noticeable improvement, and i've been running them for almost a year. pulled them recently and they look good, and the bike is running good. the parts bike last ran in the early 90's.
Offline grcamna2
« Reply #6 on: March 29, 2012, 07:25:32 PM »
I've always had good life & performance from NGK's...as long as the jetting is "on" and it isn't burning oil or trying to run stale fuel..those NGK's last for the standard duration.
I may try a set of ND's for my next time and do a comparison.
« Reply #7 on: March 29, 2012, 10:58:41 PM »
If you hit the highway with a 17T countersprocket and run 80+ MPH, they will be spot-on heat range for the run. That's how you can travel 100 MPH for 1000 mile back-to-back days, for weeks on end. ;)
For anything else, they are too cold. Try using Shell gas, regular grade, to help keep them clean in normal riding.
Offline phil71
« Reply #8 on: March 29, 2012, 11:34:39 PM »
I put the ngk precious metal plugs in my K1 and was very happy with the gain in throttle response and overall crispness... Though , at puttering speeds they load up a little.
Offline Johnie
« Reply #9 on: March 30, 2012, 06:05:05 AM »
I have had excellent performance with the NGK D8EA in every bike so hate to put these in. I may just take these 9's and exchange them for some more D8EA. I could say it was a gift and no receipt at the local store. Maybe they will do the exchange for me. I actually found these at a liquidation sale. Figured $1 a plug is a good deal.
Oshkosh, WI  USA
« Reply #10 on: March 30, 2012, 08:19:46 AM »
For some reason I just don't see you doing that Johnie. I think before you were done you would be shaking,asking the store to call the police and confessing your sins for all to hear and begging to be taken away.  :)  :)
Offline grcamna2
« Reply #11 on: March 30, 2012, 08:26:16 AM »
A sohc4 forum member w/ Hot coils can use that heat range as standard plugs..just offer them up for sale here for.... $1.50 per plug.
Offline john_matrix
« Reply #12 on: March 30, 2012, 08:47:15 AM »
Ok, I have a stupid question:
I just ordered the Denso plugs. You don't need to gap these before you put them in, do you?
Stock bike here.
1977 CB 750K
Offline LesterPiglet
  • 1977 CB550F2
« Reply #13 on: March 30, 2012, 08:49:52 AM »
It would be a good idea to check them and then decide.
« Reply #14 on: March 30, 2012, 10:01:09 AM »
Johnie, I use D9's in my race bike, I'll buy them if you haven't done anything with them yet. Too bad though I just bought a bunch.
PM away.
Offline grumpy
  • ..... '73 750K3 .....
« Reply #15 on: March 30, 2012, 10:18:02 AM »
FWIW
The Densos are a touch too hot for my K3. The D8eas work better - but 95% of my driving is on the freeway at 5,000+ RPM.
