Author Topic: removing grease zerks on my swingarm  (Read 5713 times)
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
Re: removing grease zerks on my swingarm
« Reply #25 on: March 31, 2012, 09:40:41 PM »
Damn, nobody said nipple yet.   :P
Because we are too busy talking about "shafts"...   heh heh   uhhh heh heh heh uhhh heh heh
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline Tamothy
« Reply #26 on: May 22, 2012, 06:26:48 PM »
I have a 1977 CB550F and it has one threaded grease fitting (6mm) in the middle of the swingarm pivot.  I suspect the fitting is the Japanese style mentioned, so I replaced it with a regular U.S.A. fitting (6mm) that I purchased at a cheesy auto parts store.
The grease must be old and solidified because when I attach the grease gun to the new fitting, grease is force out between the fitting and nozzle.  Is there an effective solution to this without disassembling the swingarm to remove the old grease?
I don't feel any side to side movement with the wheel removed but shocks installed.  By the end of the year, I will happily send it to HM for a rebuild but for now I would like to perform maintenance and get a chance to ride it a bit.
I haven't created a thread for my project, but I am freshening up a last-plated in '88 w/ 14k miles.  After the summer, I plan to rebuild the whole bike.
Current Bikes:
'76 XL350 - just picked it up, will be my forest road/camping machine
'77 CB550F - going to get it top-notch, like ride across the country top-notch, like it is 1980 and it has 12k miles with a loving, original owner
'82 CB900F - my (sometimes) daily rider
'74 RD350 - 6k miles, straight out of a barn, waiting for restoration
These old bikes are teaching me a big boat load!  I love 'em!
Offline kpier883
  • is quite the
« Reply #27 on: May 22, 2012, 07:21:42 PM »
Try pulling the grease fitting out then spray solvent in using one of the "straws" like the ones that come with wd40.  Shove the straw in through the grease so that the solvent gets mixed with the grease. Stick the grease fitting back in and use the bike for a few days.  Repeat every few days for several cycles then try the grease gun again.  I have had success with that on old trucks.  It is easy and won't take much time.  No real downsides if it doesn't work.  This might work better on the units with fittings on each end...
« Last Edit: May 22, 2012, 07:27:23 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline Flying J
« Reply #28 on: May 22, 2012, 07:30:36 PM »
your best bet is to find an early swingarm bolt with the nipples on the ends. They grease better so when you send it in to hondaman your rebuilt swingarm will last longer. In the mean time you could put it on the centerstand and pull the bolt out and clean it then try and grease it again.
Offline lucky
« Reply #29 on: May 22, 2012, 07:54:14 PM »
OK I've been working on the bike and have found that the swingarm spindle is full of old solidified grease. Are the grase zerks removable? If not how do I get the old grease out?
The old fashioned way. A rag and a stick. You know how to do it ,now just get down to it.!LOL,,,,ol..lol
