Author Topic: 4 into 1 or 4 into 2 exhaust?  (Read 5564 times)
Offline 75 super sport
« on: March 29, 2012, 08:56:22 PM »
Just wondering if anyone had any helpful advice in helping me make a decision on which exhaust system to go with. I have been looking at a mac 4 into 2 exhaust and was curious as to if there are any significant power losses in going with the 4 into 2 instead of 4 into 1. Thanks in advance for the advice.
"Smoke em if ya got em"
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
Re: 4 into 1 or 4 into 2 exhaust?
« Reply #1 on: March 30, 2012, 09:12:22 PM »
Well, this is an opinion from all that I've read. 4 into 1 is the best exhaust that you can use for performance. 2nd paragraph here,http://www.satanicmechanic.org/exhaust.shtml . And here is a Quote from Ken at "CycleX" > "In my opinion, any 4 into 1 system is better than drag pipes and most other cool looking systems."  I can't find any other links at this time but more should chime in. Hope this helps.   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline trueblue
« Reply #2 on: April 01, 2012, 05:25:33 AM »
What performance aspect are you looking to improve peak power at or near red line?  Or, cruise power,  low end grunt, etc?
Or, is it primarily all about how it looks and sounds?
A 4 into 1 "can" improve peak power at high RPM if the pipe size (diameter) is selected carefully and the header tubes are all equal/tuned length for the engine's breathing and RPM parameters.  That same exhaust will be inefficient and actually lose power capability in the low and mid range operation.  It is why this is a popular race option.
A "crossover" 4 into 2 can improve the low and midrange RPMs.  The crossover (2&3 share a muffler -1&4 shares the other) makes each exhaust outlet have a 180 degree timing and exhaust note, while improving scavenging.  It won't make as much peak power at High RPMs as a properly designed 4 into 1.
Most 4 into 2's have 90 degree pulses as they tie together 1&2 or 3&4.  And, these don't really provide much if any performance boost, but you may like the sound they provide.  They are usually pretty cheap, too.
The 4 into 4 discounts or eliminates any scavenging aid from any other cylinder.  However, joined exhaust pulses (as in other systems) don't foul the scavenging of any cylinder, making the exhaust very straight forward to tune, and works well at pretty much all RPMs.  The drawback here, of course, is the weight of four separate exhaust systems.  But for street use, it gives good power at low, mid range, AND high RPM, but will not get the "scavenge boost " effect at RPMs where a 4 into 1 system can be "tuned" to provide benefit.
Edit: corrected the crossover pairing reference.
1979 CB650Z
Offline Flying J
« Reply #3 on: April 01, 2012, 11:01:45 PM »
All the old honda race bikes were 4-4.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #4 on: April 01, 2012, 11:27:45 PM »
Run what you think looks good, and no there won't be significant power loss either way.
