Author Topic: CB125 6 volt system putting out 30volts?  (Read 1532 times)
Offline Billy Bones
« on: March 30, 2012, 01:52:00 AM »
Hi folks, I'm new here. If this post should have gone somewhere else, just let me know.
I bought a CB125 for $300 last weekend. Only looked at it for a second, and it started and ran alright, so it came home with me. Lights didn't work. No big deal. So I checked the fuse and it was no good replaced it. That's when I realized there is no battery. Voltometer says around 12v at idle, and 30 when revved! Any ideas for me? Am I gonna kill the coil with this much voltage?
Billy
Offline kirkn
Re: CB125 6 volt system putting out 30volts?
« Reply #1 on: March 30, 2012, 03:49:18 AM »
What year 125?  The ignition / charging systems changed once or twice over the years.  In the early years, they were a 'combined' system, and they won't generally run without a battery without some fairly involved mods.  Later, the ignition was 'separated' from the charging/lights, and they'd run without a battery.  This sounds like what you may have.
If so, then it sounds like you're reading the charging voltage, which is independant completely from the ignition system.  In that case, you've got no worries.
So, what year?
By the way, welcome aboard!
Kirk
Offline Billy Bones
« Reply #2 on: March 31, 2012, 02:17:12 PM »
Thanks Kirk! It's a '72. I am measuring the voltage from the wires where the battery would be hooked up if there was one.
Offline grcamna2
« Reply #3 on: March 31, 2012, 08:16:53 PM »
Install a battery & then test it.running it w/o one could damage the rectifier.
Offline thrutheframe
« Reply #4 on: April 01, 2012, 07:08:20 AM »
That rectifier needs a load on it to work correctly and yes no load can kill it.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Billy Bones
« Reply #5 on: April 01, 2012, 10:41:28 PM »
Thanks guys!!! I'll get a battery in there and see where I'm at.
Billy
Offline grcamna2
« Reply #6 on: April 03, 2012, 09:20:46 PM »
Billy, It would be good to test you're Rectifier; do you have a Service Repair Manual for it ?
Offline Billy Bones
« Reply #7 on: April 24, 2012, 12:28:04 AM »
Just got my hands on a manual. Hopefully get some time in on this bike soon.
Offline grcamna2
« Reply #8 on: April 24, 2012, 06:57:14 AM »
Excellent !  :)
Offline mono
  • Definitely no
« Reply #9 on: April 24, 2012, 07:13:10 PM »
i was thinking about this and to me, it seems like you're just getting 24v for free.  hook up a TV and a blender to it.
