Author Topic: Just a thought on electrolosis  (Read 580 times)
Offline trueblue
« on: March 30, 2012, 03:06:11 AM »
I was just thinking, if you can use electrolosis to remove rust from a fuel tank, why can't you use it to galvanise the inside of your tank, I was thinking of getting some annodes like I use on my boat to prevent corrosion, melting them down and making rods out of them then placing these in the tank to coat the inside of the tank with zinc.  Is there any reason why this won't work.
1979 CB650Z
Offline Bailgang
  • Scott
  • Indiana
Re: Just a thought on electrolosis
« Reply #1 on: March 30, 2012, 04:56:26 AM »
It can be done I suppose however from what I understand the process is much more involved than simply using a zinc anode and switching the terminals on the battery charger. Hopefully someone here with experience with plating can explain it better.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Lostboy Steve
« Reply #2 on: March 30, 2012, 08:48:02 AM »
No it wont work like that. Youtube it. You need to make a solution out of the zinc. It requires acid and seems quite involved or else I would have done it.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
