Author Topic: Leaking Petcock  (Read 1106 times)
Offline CB500_k2
  • Wrenching makes a good retirement.
Leaking Petcock
« on: March 31, 2012, 04:24:01 PM »
Well thanks for all the information on a reasonable price for a CB 350.  I have not been dissuaded from selling and I was getting the machine ready to show off.  I added fuel to the tank the carb overflows started draining even though the petcock was shut.  A couple gentle wacks with a piece of wood got the needle valves to shut.  Then I found fuel leaking out of the petcock.  I tightened the screws and this slowed things down.  Is it just that the rubber seal is dry or do I have to get a new one.  I am letting everything soak in gas and I have a funnel placed under the petcock to divert the drips away from the engine.  I must say that the bike started up immediately after three years dormant and was a delight to drive.  Of course I had to replace the battery and unbind the front brakes before I could get out and about.
Do I need to get a new gasket or will it swell with hydrocarbons and seal???
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline Spanner 1
Re: Leaking Petcock
« Reply #1 on: March 31, 2012, 06:14:37 PM »
I'm still waiting for mine to re-seal a week later ;D... don't think time/gas will help !.... I just got a new rubber washer today. It should be Honda part # 16955-268-020 if your petcock is the same dia. as the bigger bikes ( ( think it is )... Good luck.
Offline bharvey60
  • Adolescent mind stuck in an adult body
Re: Leaking Petcock
« Reply #2 on: March 31, 2012, 06:44:01 PM »
Make sure there are rubber washers on the bolts to the tank.  If not, gas will leak past the bolts into the bowl.  You can use o-rings as well.
Sent from my DROIDX using Tapatalk
Bill Harvey
CB750K3
85 Yamaja FJ 1100
98 BMW R1100RT
State College, PA
Offline CB500_k2
Re: Leaking Petcock
« Reply #3 on: April 02, 2012, 02:24:46 PM »
Thanks,  I forgot about those rubber seals between the tank and the petcock.  Time to go to my Honda shop and get some new rubber.
1973 CB500
1974 CB350 - sold
