Author Topic: Black Jack 1978 K8 750cc  (Read 23460 times)
Offline Familyvan
« on: March 31, 2012, 04:44:33 PM »
Well ive been monitoring this forum for a while and slowly progressing with my own project, so its now my time to update you all
I bought a 1978 750CC K8 honda off Ebay from a bloke in scotland.
The bike was described as a runner, but had been stored for approximatly 3yrs
The bike started but was very rough and lumpy.
Shorten the rear fender and fitted a LED rear light
New front Wheel 2.10with a Cb550 hub, powder coated black and annodised wheels and stainless steel spokes
New 8" headlight with bullet indicators
Im liking this design to be on the tank
Hence the bikes name of "Black Jack" thinking of using a Gun metal Grey in there too
Offline LesterPiglet
  • 1977 CB550F2
Re: Black Jack 1978 K8 750cc
« Reply #1 on: March 31, 2012, 05:52:58 PM »
What is it with the gigantic seats or is it a trick of the light?   :o
I hate our gigantic number plates as well.
I'll look forward to updates.
Offline Familyvan
« Reply #2 on: April 01, 2012, 01:35:59 AM »
The seat is gone, and so has the number plate. lol
Going to make a custom seat, more picturesto follow
Offline Mugen_Stumpo
« Reply #3 on: April 01, 2012, 05:21:30 AM »
the first shocks abs are marzocchi repainted???... willing to sell?
Offline Familyvan
« Reply #4 on: April 01, 2012, 01:07:01 PM »
Offline KB02
« Reply #5 on: April 01, 2012, 01:22:35 PM »
You will be so happy that you did that. 8)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
  • 1977 CB550F2
« Reply #6 on: April 01, 2012, 02:02:06 PM »
Get some goggles on.  8)
Offline lucky
« Reply #7 on: April 03, 2012, 11:20:33 AM »
Yes ...get those goggles on bro!!
Offline Familyvan
« Reply #8 on: April 06, 2012, 05:38:41 AM »
First of all that's not me!! I've got less hair. I will have a word!!
Have been arranging the electronics on the battery box
also I have acquired a F1 tank, so slightly slimmer looking
Offline Familyvan
« Reply #9 on: April 06, 2012, 08:09:34 AM »
When we split the engine, the pistons were sloppy in the barrels
After looking around I decided tofit a set of 836cc big bore kit.
We ported and polished the hea a little and fitted a slighty faster cam.
I'll get the exact spec to follow.
Offline Familyvan
« Reply #10 on: April 06, 2012, 08:12:27 AM »
Cx2 cam.
Offline lucky
« Reply #11 on: April 07, 2012, 08:03:17 PM »
Cx2 cam.
If you put the words CB750 with Cx2cam THEN GOOGLE THAT you get Ebay>Cycle-x! 41A cam.
Offline Familyvan
« Reply #12 on: June 07, 2012, 12:49:00 PM »
Honda VFR 800 discs
Harley front fender
Offline Familyvan
« Reply #13 on: August 03, 2012, 12:19:19 PM »
Engine stripped down to clean and a hole found in gearbox casing.
Popped down to my mates garage to weld up the hole
All glued up
Offline Familyvan
« Reply #14 on: August 03, 2012, 12:20:20 PM »
My assistant over keen to help out!!
Offline Familyvan
« Reply #15 on: August 03, 2012, 12:21:58 PM »
Cleaned and ready to go!
Engine case painted inside and out
Offline Familyvan
« Reply #16 on: August 03, 2012, 12:23:33 PM »
F1 side panels fitted
Offline xnoahx
  • 78 750K
« Reply #17 on: August 03, 2012, 06:00:46 PM »
Looks good
Offline lucky
« Reply #18 on: August 06, 2012, 10:13:50 AM »
All glued up
When you see that red or blue RTV expect trouble. It is the sign of a real amateur.
Offline lucky
« Reply #19 on: August 06, 2012, 10:18:05 AM »
If I was welding that case I would have wanted it spotless before welding.
 It seemed very dirty to be welding on it.
 Did both sides if the crack or hole get welded?
Offline Familyvan
« Reply #20 on: August 06, 2012, 12:30:26 PM »
Both sides welded up, cleaned and painted
Just starting to put it all back together now.
Offline bytio
« Reply #21 on: August 06, 2012, 01:52:23 PM »
What is the red paint used on the inside of the cases?
Offline Familyvan
« Reply #22 on: August 07, 2012, 01:50:22 AM »
Glyptal engine paint
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #23 on: August 07, 2012, 07:30:58 AM »
You know you're clocks are switched? Might not be an issue unless you're going to use the stock dash light panel, then the trip odometer reset knob may interfere.
Looking good so far!  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
  • 1977 CB550F2
« Reply #24 on: August 07, 2012, 12:06:59 PM »
Nice clocks. Is that the F3 paint job on that tank?
