Author Topic: relocating petcock?  (Read 1036 times)
Offline davesee
relocating petcock?
« on: April 02, 2012, 05:14:03 AM »
i'm working on my cb650, and have replaced the tank with one from a '74 cb450. it looks great, but the petcock is located right above the carbs, and so there's no room for it. i want to cheaply relocate the petcock (plugging the original bung) by using a universal type like this one http://motorcycle.motorcycle-superstore.com/motorcycle/Universal%20Petcock. it looks as simple as drilling a new hole and screwing in the plate. is it?
has anyone tried something like this? recommended?
thanks
1980 honda cb650 with many weekends worth of modifications.
Offline ultrav
Re: relocating petcock?
« Reply #1 on: July 19, 2014, 01:08:16 PM »
Did you try that petcock? If so, did it work? I am attempting the same exact tank swap.
Offline bjbuchanan
« Reply #2 on: July 19, 2014, 01:16:46 PM »
They work but the problem is that you can't really take it off much, or probably more than once. Those self tapping screws probably won't grab again
« Reply #3 on: July 19, 2014, 01:36:32 PM »
I make an adapter 16 mm i think to 1/4 npt.. Then the guys use pingel petcocks
