Author Topic: Wiring harness issues on CB400f  (Read 1039 times)
Offline DynoDon
« on: April 02, 2012, 08:45:53 AM »
I'm not real swift with wiring, I replaced the right and left handle bar controls on my 75 CB400F.
Some of the colors of the wires coming from these controls, do no match up with the wires coming from the
main harness under the tank. What tools and reference do I need to sort out these connection, and those in the headlight bucket
Thanks
Don
Offline CycleRanger
  • No comment about being an
Re: Wiring harness issues on CB400f
« Reply #1 on: April 02, 2012, 08:52:47 AM »
The shop manual contains a wiring diagram.
You can download a pdf here:
http://honda4fun.com/materiale-documentazione-tecnica/shop-manual
Offline Toxic
« Reply #2 on: April 02, 2012, 09:09:27 AM »
Did you replace the controls with ones specific to your year, make or model?
If not then you will also need the wiring diagram for the year they were designed for .
With the two manuals you should be able to determine which wire performs what function.
If don't know what year they are from you are going to have to open up the controls and make a list of what wire does what function and then compare it to your stock wiring diagram.
Offline DynoDon
« Reply #3 on: April 02, 2012, 10:33:52 AM »
 CycleRanger and Toxic, thanks for the info.
They are from the same year and model, so the shop manual should do the trick.
Don
