Author Topic: RE Sprocket sizes 550  (Read 1523 times)
92t0rider
« on: June 05, 2006, 04:16:34 PM »
Hello
Im interested in replacing rusted spokes with cast wheels, they look so good!
I'd prefer a replacement from another honda because this is a bit of a budget bike.
EDIT: after looking around Ive found somone that used a 78 cb400t front end and spacer/shim in the rear. I'd like to keep the 550 front end if possible. Can I just simply buy a new sprocket (37t) on a mag wheel?
Ive been attempting to use http://partsfinder.ridenow.com/fiche_select.asp?vcc=Motorcycles&mfg=Honda&year=1977
to locate a year with appealing cast wheels with the right sprocket but Im feeling like a blind guy searching for the honey pot.
Any info on what model/year cast wheels will fit the 77 550?
Thanks
« Last Edit: June 06, 2006, 12:20:34 AM by 92t0rider »
Offline neil young
  • striving to be an
Re: RE Sprocket sizes 550
« Reply #1 on: September 15, 2007, 10:32:23 PM »
bump
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
« Reply #2 on: September 16, 2007, 05:34:37 AM »
None directly but anything is possible if you have machining facilities. Comstar, in my opinion, are the biggest heap of crud going
Offline neil young
  • striving to be an
« Reply #3 on: September 16, 2007, 11:36:58 AM »
why ?
1972 CB500 k1
1974 CB550
1977 cb 550
eldar
« Reply #4 on: September 17, 2007, 06:42:26 AM »
Comstars are better than spokes any day as far as function goes. People just do not like the way they look. At least most people do not. After all, there is a reason why spokes are not used in racing, even back when the comstars came out.
