Author Topic: DANGIT! I broke the clutch lifter.....  (Read 451 times)
Offline DedHed
  • Boob
« on: April 04, 2012, 03:23:44 PM »
74 CB 750 K4, Stock....
I read about 7,987 times to be careful tightening the lifter bolts, 1 complete turn until snug then 1/4 turns to torque (6 to 8 Ft/lbs).... I followed the instructions to a "T" .... However my torque wrench got the better of me >:( >:( >:(
I have one of those twisty handle torque wrenches....
The first graduation on the "Rough" side of torque wrench is 10 ft/lbs.... The "Fine" adjustment goes from ZERO to 9.. Simple right? not for this numbskull...... :o
I set the rough adjustment at Zero, the fine adjustment at 6. Dialed in at 6 ft/lbs... Off I go....
1/4 turn, next bolt, 1/4 turn, next bolt, 1/4 turn, next bolt, 1/4 turn, next bolt, 1/4 turn, next bolt, 1/4 turn, next bolt, 1/4 turn, next bolt, 1/4 turn, next bolt, 1/8 turn....**TINK**  :'(
 After wiping my tears and apologizing to the dog yelling at him and blaming him... I tried the same torque value to a random 10mm bolt... No click click...WAY more than 6 lbs.  I dialed it UP to 16 Ft/lbs, tried the same random bolt and click click... DANGIT!!!!!
I should have known better than trusting a wrench that goes to 100+lb torque to a 6 lb setting.... DANGIT!
$50 bucks for a new lifter plate.... DANGIT!
My humble question...
Am I safe tearing into a junked (70ish to 77ish) Honda engine from the scrapyard and using that? Compatible????? Am I asking for more trouble by using a suspect part? If'n I do get a used one, or new one for that matter... Do I need to get a new bearing?..... DANGITl!
No animals were harmed during this rookie mistake......
My name is Phil .... I am an idiot.... "Hi Phil" ......
DANGIT
« Last Edit: April 04, 2012, 03:53:45 PM by DedHed »
CB750 K4
