Author Topic: the '750FK'n Mutt'  (Read 25055 times)
Re: The Mutt - '78 K8/K1
« Reply #25 on: May 01, 2012, 02:06:06 PM »
finally got to my carb vacuum sync, and my friggin' #4 slide/idle adjustment screw/nut is stripped   >:( &$@#!
it just spins in place.  Thankfully, i'm pretty close to being balanced.  A whole rack of PD42b's are $100+
i just need that little slide arm.
time to search rebay.... :-\
Offline knowsnothing
« Reply #26 on: May 01, 2012, 04:58:05 PM »
Hey flybox, send sohc digger a pm or check his for sale thread.  He does a lot of carb cleanings/repairs and has a bunch of spare parts.  He might be able to help with what you need.
1978 CB750k Blue - for sale
« Reply #27 on: May 01, 2012, 05:00:09 PM »
« Reply #28 on: May 01, 2012, 08:18:47 PM »
^thanks for that referral, kn
Offline lucky
Re: The Mutt - '78 K8/K2
« Reply #29 on: May 01, 2012, 10:40:45 PM »
Not yet. Might see if I can get this spot brazed?
Metalwork and welding is an art I know very little of.
Played with my new eBay gauge faces...
You did a beautiful job on the gauges!! WOW!!
« Reply #30 on: May 05, 2012, 08:27:21 PM »
Ditched the cheap Chinese LED blinkers for some smaller, nicer, round signals. Front wheel came off today for some deep cleaning on the rims and spokes.
Removed the front caliper for a fresh piston seal and new EBC pads.  34 years of isht hiding in there  :o
All came apart pretty easily. Had to pump the piston out with the fluid and brake lever. Cleaned up easily enough.
Fresh coat of paint added too...all balls bearings and ss brake line from slingshot cycles on the way....
« Reply #31 on: May 06, 2012, 03:30:10 PM »
Had some time today.  Front fender had a few dents out on the tip, so I chopped, sanded and repainted.
« Last Edit: July 03, 2012, 12:48:04 PM by flybox1 »
« Reply #32 on: May 13, 2012, 08:35:37 AM »
Front and rear were off for spoke cleaning.  Installed new all balls bearings in both.
Repainted front brake rotor hub.  New emgo brake shoes on rear.  Light polishing on rear brake plate.
Everything went back on fine and i notice a 3mm-4mm wobble on my rear. It's gonna have to come off for truing and a rebalance.
Went to bleed my front with new ss lines, and my MC is blocked. Can't free up the holes in the cup, so MC rebuild kit on order.
Started tank paint removal on my PO flat black rattlecan job.  CitriStrip is Nice to work with. painted it on before bed. 8 hrs later it produced this rubbery mess. Scrapes off easily. Residue wipes off with mineral spirits.
« Last Edit: May 14, 2012, 09:48:23 AM by flybox1 »
« Reply #33 on: May 13, 2012, 08:36:59 AM »
Looks like red primer?
« Last Edit: May 13, 2012, 08:41:26 AM by flybox1 »
Offline tweakin
  • tear down
« Reply #34 on: May 13, 2012, 09:32:04 AM »
Making some great progress!
« Reply #35 on: May 13, 2012, 01:33:30 PM »
Yeah. Its nice to see  ;D thanks t!
1 hour with mineral spirits and a 3M pad...
New territory for me - Paint.   Have to get these light impressions out first.
Maybe a sandable spray primer/filler?
« Last Edit: May 14, 2012, 09:42:36 AM by flybox1 »
Offline brandEn
« Reply #36 on: May 13, 2012, 03:01:14 PM »
I say Rhino Line it! :D
« Reply #37 on: May 13, 2012, 03:18:28 PM »
Hahahaha branden...I'm considering it. Something textured would be good.
This CB would look odd with a stellar paint job similar to the ones you and tweaking have.  That'll have to wait for the next project.
« Last Edit: May 13, 2012, 03:58:22 PM by flybox1 »
« Reply #38 on: May 15, 2012, 02:50:04 PM »
Makin' hay in the PNW. My first go at rattlecan.
4 coats etching and 4 coats sandable primer. Easy.
Now to do work.....
« Reply #39 on: May 21, 2012, 08:43:55 AM »
to all of you who do paint and bodywork, i give you props  8)  my first attempt a prepping a tank for paint.
time consuming 12 coats of sandable filler primer, wet sanded w 400 after each 3 coats, to get this point. It looks like new. Paint flies this weekend.
..and a little refresh of my tank badges.
« Last Edit: May 21, 2012, 08:45:29 AM by flybox1 »
Offline steakCB550K
« Reply #40 on: May 21, 2012, 09:32:41 AM »
Lookin good so far, I love the speedo and tach lights.  Keep up the good work.
77 CB550K
78 CB550K
77/78 cool 2 member
« Reply #41 on: June 04, 2012, 09:05:27 AM »
thanks to members nvr2old (for the inspiration, great work) and to Kong(for great tips)
3 long weekends of sanding and painting.  Spraymax 2K clear went on and looks good.
covers by frankenfrankenstuff.
one last sanding tonight and then polish....but not before a photo op  ;D
picking up the seat from the upholsterers later this week.
Offline brandEn
« Reply #42 on: June 04, 2012, 09:13:25 AM »
HOLY SHYTE! Looks amazing Mr. Box. Mad props for your rattle can skills and garage paint job. I hope to see it in person sometime soon.
« Reply #43 on: June 04, 2012, 09:17:45 AM »
Thanks b!
a few things i will have to do differently next time, but pretty pleased w/ it.  :)
« Reply #44 on: June 10, 2012, 04:41:26 PM »
The finished product.
He doesn't get it for another 7 years ;)
Thanks to everyone who helped me get this one back on the road!  8)
« Last Edit: June 10, 2012, 08:10:18 PM by flybox1 »
Offline brandEn
Re: The Mutt is Done!!!
« Reply #45 on: June 10, 2012, 04:56:26 PM »
cool!
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #46 on: July 03, 2012, 09:21:46 AM »
Sweet job fly! Nice job on the gauges I may have to come up and let you put my originals back together. And super nice job on the paint. It's fun enit? Gotta love a white SOHC4. Too bad Honda never thought of that.
Hope to see you around the sound.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #47 on: July 03, 2012, 10:05:19 AM »
Looks awesome.
Congrats
« Reply #48 on: July 03, 2012, 10:49:55 AM »
The Mutt v2.0 ;D (holy pipes were bugging me  ::) )  trying out this small internal baffle for a few weeks.  its just 2.5" x 6" and has nothing wrapped around it.  its just straight through.  DB Killer, IIRC.  If I get too many complaints from the spousal unit, i'll order that reverse cone slip-on from coneeng  :P
« Last Edit: July 10, 2012, 01:43:56 PM by flybox1 »
Offline tweakin
  • tear down
« Reply #49 on: July 03, 2012, 01:47:26 PM »
Just saw that you completed this.  Well done, looks great.
