Author Topic: '76 cb750 carbs on a '77 cb750k????  (Read 982 times)
Offline icmock
« on: April 09, 2012, 09:04:38 AM »
From what I've read, it seems like this set up would work.   I was wondering if I will need to use the '76 throttle cables tho.
If so, will the 76 cables jive with the threads, throttle tube and control housing on my 77?
I'd rather have a bottle in front of me, than a frontal lobotomy
Re: '76 cb750 carbs on a '77 cb750k????
« Reply #1 on: April 09, 2012, 09:07:24 AM »
You would be going backwards. Thw 77-78 PD carbs are better. Yiou have an accel pump which gives better response  when clean and adjusted properly.
Offline icmock
« Reply #2 on: April 09, 2012, 09:23:18 AM »
True, however the 77 set I have is damaged, and I was able to pick up a rebuilt 76 at a great price.
So, I would like to try and make the 76 set work.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: April 09, 2012, 10:45:41 AM »
Straight swap, though you'll need the earlier air box & carb boots too. Good luck!
Offline icmock
« Reply #4 on: April 09, 2012, 10:59:16 AM »
Thanks.
I have 76 boots, and using pod filters.  Still not sure about the throttle cable length.  Looks like the linkage set up is different between 76 and 77.
