Author Topic: Front Sprocket  (Read 1053 times)
Offline Bido
Front Sprocket
« on: April 09, 2012, 10:58:36 AM »
I removed the front sprocket on my 78 750 F/3 to change it to 14 tooth stock sprocket the PO had a 15 tooth in there. The 14 tooth stock sprocket has a sholder on one side could someone tell me which direction the sholder should go towards the motor or away from the motor? I have looked all over for this info with no luck I am sure there is a reason for the slight offset.
Thanks in advance
Bido
1978 CB750 Supersport F3
1981 CB750 K
Re: Front Sprocket
« Reply #1 on: April 09, 2012, 05:33:28 PM »
I just did my 78K over the weekend and that shoulder goes on the inside toward the engine.
Offline Bido
Re: Front Sprocket
« Reply #2 on: April 10, 2012, 03:26:39 PM »
Bobby
Thanks for the reply I had a feeling that was the way it went the # 14 is stamped on the side without the shoulder so you could read it without taking the sprocket off my way of thinking anyway.
Thanks again
Bido
1981 CB750 K
Offline lucky
Re: Front Sprocket
« Reply #3 on: April 10, 2012, 03:28:01 PM »
Yes...right the shoulder always goes on the inside.
Re: Front Sprocket
« Reply #4 on: April 10, 2012, 04:26:20 PM »
Bobby
Thanks again
Bido
Bido, my pleasure we all help each other. I put some blue loctite on the bolt. I have red but that seemed like overkill.
Offline Bido
Re: Front Sprocket
« Reply #5 on: April 10, 2012, 04:54:24 PM »
I have to say one less tooth on the front sprocket was the best performance increase I have made so far like a new bike.
Bido ;D
1981 CB750 K
Re: Front Sprocket
« Reply #6 on: April 10, 2012, 05:21:41 PM »
I think 14 was the stock. Some people try to lower the RPMs at highway speed. Now you get into the torque band in a different spot.
