Author Topic: Re: K Two *** [FINISHED] ***  (Read 32080 times)
Offline MoMo
  • Ride like you're invisible
Re: K Two
« Reply #75 on: March 25, 2013, 12:59:44 AM »
Very nice, what's with all the electronic gear in the back ground?...Larry
Re: K Two
« Reply #76 on: March 25, 2013, 06:04:30 AM »
Looking great, won't be long now.
Re: K Two
« Reply #77 on: March 25, 2013, 06:36:11 AM »
Very nice work Jerry. She is going to be stunning when you are finished. Definitely BOTM material here.
Nice set of electronics gear, so you dabble a bit in electronics repair/design or ham radio?  That an old Simpson VOM on the left?  Been a long time since I've seen one of those. Reminds me of my days in the electronics lab back in college.
David
Offline Garystratos201
  • I have never been a
Re: K Two
« Reply #78 on: March 25, 2013, 06:58:39 AM »
Great work as always. Be sure to video the initial startup..............Gry
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline Vinhead1957
Re: K Two
« Reply #79 on: March 25, 2013, 09:06:55 AM »
Frequency generator and counter?  Mmmmm. Come in Tokyo. By the way, outstanding job on the bike.
Offline brandEn
Re: K Two
« Reply #80 on: March 25, 2013, 09:38:18 AM »
Wow things are shaping up nicely.
Offline jerry h
Re: K Two
« Reply #81 on: May 06, 2013, 10:44:37 PM »
Wow... time flies!  Been busy (consumed more like) with trying to get this project done, that I've been neglecting the updates.
One of the few non stock items on the bike is the oil pressure gauge.  If your a first timer like me, you may be wondering what's involved....   here's what I came up with.
Materials needed:
-pressure gauge 0-100 psi (such as: http://www.ebay.com/itm/360166102625?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D360166102625%26_rdc%3D1)
-1/8" NPT elbow (male/female) - I used a Watts A-712 (such as:  http://www.homedepot.com/p/Watts-1-8-in-Brass-90-Degree-MPT-x-FPT-Street-Elbow-A-712/100616533?keyword=a-712#.UYiCZ8r97ah)
-"Q" drill
-1/8"NPT tap
I removed the galley cap, drilled a hole in a block of wood big enough to screw the cap into (to hold it on the drill press), used the "Q" drill to drill a hole in the center, followed by the 1/8NPT tap, clean and assemble.  I love it.... if the idiot light ever goes on, you can immediately verify if there's pressure, or if the warning light sensor is failing.
Last item to go in the engine was the oil pump.  I figured with the gauge, I could tell if it was good or not, so no need to delve into the pump, just clean the outside, prime in a bucket of oil, then install.   Ok ready for the big fire up.  Kicked over several times with key off, and what do you know... oil pressure!  Turned the key on and it started on the next kick!  Caught me off guard, thought it would be more of a task to get it started, that I immediately hit the kill switch ;D.   Did a few trips around the block, and all seems well.  Cleaned up and prepped for a proper test drive tomorrow.
Big test drive day..........  got bike started, while warming up I was getting the gear on, I see the oil light go on!  Quick check of the gauge, its at zero too,   this is where the kill switch comes in handy!   Put helmet and gear away and started troubleshooting.   The only thing I could come up with is the pressure relief valve stuck open, resulting in a sudden loss of pressure ?  After 15 minutes, I kicked it over, and the pressure registered on the gauge as usual.  The anti drain back valve wasn't working either, so I decided it was time to pull the pump and venture into the rarely seen inner workings of the oil pump.
You'll need an impact driver to get in.... no need to mess with the screen, everything can be accessed after removing the 3 phillips screws on the pump body.  Although the pump was putting out good pressure, the rotors had deep gouges in them, looked horrible.  You can see a few of the gouges in the next pic,  look at the inner rotor surface (below the keyway)... and crud embedded in the outer surface.
Didn't feel like putting that mess back in the engine, so I got REAL lucky and won a $5.00 pump on EBAY!  Opened it up, and it looked almost new.  One or two scratches, but no giant gouges.  If I remember correctly, there was .003 gap between the rotors, so it should be good.   Thanks to an old post by Jerry RXMAN  (THANKS!) , I found the part numbers for the needed pump rebuild materials....
2) 91305-426-003
1) 91208-MN1-771
4) 91302-377-000
Made a custom CB750 inner pump seal removal tool (small screwdriver with bent end ;D)
I was able to lightly tap out the inner seal with this screwdriver, just go round and round several times, and it popped out.
Lightly tap in new seal (chilled in freezer previously)
New orings should be beneficial........ ;D
Spent a good amount of time at the wash tank, and cleaned everything .............. then assembled with new o rings.  The Hondaman book was very helpful in this endeavor as well.  Thanks Mark.
Ok - here's the results of pump #2 at idle....
I've since put 100 miles (test drives  ;D) on the bike, and solid pressure.... so fingers crossed.
Overall pleased at this point, but still trying to dial in the tuning before calling it done.   Slight stumble between 2.7k to 3k,  and not idling to my liking.  I think I've figured that one though ........... will discuss in the next installment.  Waiting for parts again   >:( >:( >:(             ;D
As usual.... Thanks for stopping by!
Offline Johnie
Re: K Two
« Reply #82 on: May 07, 2013, 04:58:34 AM »
Nice tutorial Master Pump builder Jerry! :) Gosh, that oil pump gauge saved your motor on this one for sure. Glad you got it sorted out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: K Two
« Reply #83 on: May 07, 2013, 05:11:56 AM »
Nice write up and bike looks fabulous
Re: K Two
« Reply #84 on: May 07, 2013, 05:39:39 AM »
Great job Jerry. What can I say but very nice work and the bike looks great........Gary
Offline iron_worker
Re: K Two
« Reply #85 on: May 07, 2013, 08:41:23 AM »
Damn! That is lookin soooo nice.
IW
Offline Johnie
Re: K Two
« Reply #86 on: May 07, 2013, 03:08:42 PM »
I am thinking BOTM for sure!!! She sure is purdy Jerry.
Oshkosh, WI  USA
Re: K Two
« Reply #87 on: May 07, 2013, 04:08:29 PM »
+1, very nice bike... ;)
Offline Johnie
Re: K Two
« Reply #88 on: May 07, 2013, 06:31:52 PM »
Hey Jerry...how about a nice full length pic of the bike for the guys here?
Oshkosh, WI  USA
Offline lwahples
Re: K Two
« Reply #89 on: May 09, 2013, 04:35:40 AM »
Just found this thread.Have been through it twice! Amazed at the detail.
Offline Johnie
Re: K Two
« Reply #90 on: May 09, 2013, 05:25:30 AM »
So last night Jerry stopped over with his K2...simply awesome in every way! We took a ride together and he even trusted me to take her for a spin. I have never rode such a nice tight 750...it felt so new and smooth. The detail is not to be surpassed. I think each and everyone of you need to test this bike out :) I will be nominating this for BOTM unless someone beats me to it.
Oshkosh, WI  USA
Re: K Two
« Reply #91 on: May 09, 2013, 07:59:34 AM »
Looks new.
Offline jerry h
« Reply #92 on: May 29, 2013, 10:16:54 PM »
Well - the last post for this rebuild thread ;D
 The last couple of weeks have been spent trying to get everything dialed in and tuned up.  Nothing too exciting to post... the usual lot of adjusting the carbs, checking timing, valves etc.   It's surprising how once your familiar with your bike, how fast you can have it from running bike to this......  matter of minutes.   (Decided to raise the needle clip position to lean out the mixture)
Few other pesky little problems, the most expensive was this little item:
Cylinder #3 lead was loose in the coil, and causing an intermittent spark.  I found that out by attaching the timing light test lead on that wire, and watching the erratic strobe light, compared to the other 3.
Another annoying problem was during acceleration, there occasionally would be a little stumble between 2 / 2.5K RPM.... tracked that down to the fact that I packed the advancer full of Timken wheel bearing grease when I cleaned it up (seemed like a good thing to do at the time). It was messing up the advancer curve ...... cleaned it up, and greased with a small amount of white lithium/ and good quality oil....... now smooth acceleration from 0 on up.
After a while my neutral light started flickering on in any gear.  Found out you can take apart the neutral switch and "restore" it.  The bottom plug screws off, and there is a ball bearing, spring, and two brass contacts inside.  Clean the contacts up with some 400 sand paper, clean the rest up, and re-assemble (I used some "Form a Gasket" on the plug threads) - works like new.
That's the tune up highlights... ::)  K2 is running good now, so that's going to be it, until the 3K tune up.
Last up was putting on some stickers and smearing yellow paint everywhere  ;D
And I've been debating for a year if I want to put this one on or not.... but eventually it seemed like something was missing.  Now I won't forget to preserve nature ;D
I would like to thank all of you who have posted your advise and tips on this forum over the years.  I spent many hours  digging through the archived old posts.... its amazing how you can find an answer to almost any problem.   THANKS!!!!!!!
Also a special thanks to Johnie..... who helped me out a ton!!!  I'm fortunate enough to live nearby, and able to stop over and visit.  Of course his bikes all look amazing, so the plan was to try and copy as much as I could from him.  Whats the phrase...   "Imitation is the sincerest form of flattery"...... ;D   (although I've fallen short of that goal.... maybe next attempt will be better ;))
And of course.... before and after->
Thanks !!!
« Last Edit: May 30, 2013, 09:56:39 PM by jerry h »
Offline cheftuskey121
  • Super Newbie
« Reply #93 on: May 29, 2013, 10:31:24 PM »
holy moly thats gorgeous!
Offline Viktor.J
  • Breaking in the forum
« Reply #94 on: May 30, 2013, 01:46:03 AM »
That is an amazing work Jerry ! God damn that bike is beutiful ;)
How long time Did it take all'n'all ? Did you change most of The parts or restore them ?
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline Franky
Re: Re: K Two *** [FINISHED] ***
« Reply #95 on: May 30, 2013, 03:26:24 AM »
I simply love Candy Gold! I have to build something just to include that beautiful color.
Great with all the details and photos - thanks a lot.
1974 Honda CB360T Stock
1974 Honda CB550 K0 Stock
1977 Honda CB550 K3 Cafe - never ending build :)
1988 Honda Dax ST50 Cafe
1997 Honda Benly 50S Stock
Check out my "Yamaha R6 fork on a CB550 made easy" thread:
http://forums.sohc4.net/index.php?topic=118983.0;all
Offline Frankensteins Bride
« Reply #96 on: May 30, 2013, 05:27:02 AM »
She's beautiful! Hard to believe that is the same bike! Enjoy riding her!
Working on: 78 Cb750k
Waiting for arrival: 73 Cb750
Frankensteins Wolf
« Reply #97 on: May 30, 2013, 05:31:22 AM »
Amazing transformation, great job.  Will be nominating for BOTM...
Offline Johnie
« Reply #98 on: May 30, 2013, 06:31:20 AM »
Not unless I beat you to it Stev-o....the bike even looks better in person. And she rides as good as she looks. Very nice Jerry...
Oshkosh, WI  USA
Offline brandEn
« Reply #99 on: May 30, 2013, 07:02:32 AM »
That looks nice!
I really like the way you did the stripes on the tank.
