Author Topic: Piston is chipped...Can I still use it?  (Read 6638 times)
Offline thomellis
« on: April 10, 2012, 04:47:40 PM »
Hey Guys,
Newbie question...So one of my pistons has a bit of a ding in the top of it, and I have no idea if it's okay to reuse or if I need to totally trash it.  Can it just be filed down, or is that a terrible idea?
Thanks for any advice you all can provide!
Offline nayto550
Re: Piston is chipped...Can I still use it?
« Reply #1 on: April 10, 2012, 04:52:17 PM »
If it was a small chip in the middle of the crown, I would hesitantly say it could be reused.  With the chips out of the edge as it is, I would highly recommend replacement.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #2 on: April 10, 2012, 05:00:38 PM »
What bike, year, piston?
What does the cylinder look like? Pictures...
Offline thomellis
« Reply #3 on: April 10, 2012, 05:08:52 PM »
Thanks guys.
The bike is a 72 CB750, I can get a picture of the cylinder tonight.
Does anyone know if a 76 piston is the same specs?
Offline nayto550
« Reply #4 on: April 10, 2012, 05:16:16 PM »
The next important questions are:
Why is there a piece of the piston missing and where is the missing pieces?  :o
1976 CB550F
1988 HD FLHS
Offline thomellis
« Reply #5 on: April 10, 2012, 05:19:23 PM »
I have to imagine it happened after it was pulled for a couple reasons:
1) its super clean where the nick is, no carbon build up
2) I didn't notice it until a couple days after it was pulled
3) the neighbor kid who loves to run amuck in my garage swears he didn't do it :P
Offline mycb750k6
  • Rocketman
« Reply #6 on: April 10, 2012, 05:29:04 PM »
76 will work or I've some pistons you can have or others here will give you one. Decide what you need and let us know.  In any event you'll likely need  a new set of rings and hone the cylinder. Let's see the picture of the cylinder first and what's the mileage?
Offline trueblue
« Reply #7 on: April 11, 2012, 03:31:46 AM »
That piston could be used in a pinch, you would need to remove any rough edges with a fine file and make sure the top ring groove hasn't been dented but ideally you should replace it.
1979 CB650Z
Offline Xnavylfr
« Reply #8 on: April 11, 2012, 06:07:20 AM »
Looks minor to me also. I would use sandpaper and just knock the burrs off the edge and use it.
Xnavylfr(CHUCK)
Offline Raul CB750K1
« Reply #9 on: April 11, 2012, 10:25:55 AM »
I would also reuse it.
Offline phil71
« Reply #10 on: April 11, 2012, 10:50:44 AM »
that kind of mark was caused by something out of whack. Are you sure that piston belongs in that engine? Looks like a deck height thing.. unless the valve timing is way out of whack. Cam chain shot?
