Author Topic: Stuck Front Brake  (Read 1511 times)
Offline nccb
  • 1974 CB750 Four
Stuck Front Brake
« on: April 10, 2012, 05:24:38 PM »
So, I have neglected to ride my bike for a couple of weeks due to writing a thesis for graduate school and when I rode it last night I noticed that the front break didn't seem to be working well.  I could push the lever in but it was really tight.  The pads also look like they are clinched on the rotor.  If they just seem to be stuck can you pry them apart?  Also does anyone have some checks that I could run through to determine what may be wrong with the break?  I haven't checked the break fluid when I got it from the PO, I don't know if that would cause them to get stuck or not.
Offline Gordon
  • 750K1, 550K2
Re: Stuck Front Brake
« Reply #1 on: April 10, 2012, 05:37:08 PM »
Two most common things that cause a sticking disc brake on these bikes are, 1.  Crud build-up behind the caliper piston seal that prevents the piston from fully retracting, or 2.  Plugged up fluid return hole in the master cylinder reservoir.
Offline cmonSTART
« Reply #2 on: April 10, 2012, 05:41:04 PM »
Those fluid return holes are really really tiny.  They clog easily.
1981 GL1100 Interstate
1978 CB750F Project
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: April 10, 2012, 05:45:04 PM »
And don't put your face right over the reservoir while you pump the lever to see if you've successfully cleared it.  It'll shoot a stream of brake fluid right in your eye. :o
Offline fishslayeryo
« Reply #4 on: April 10, 2012, 05:54:37 PM »
What these gents said....guitar string works or anything thin...cover up your paint as well...just incase:)
'71 CB750 K1...work in progress:)
Budget Build: http://forums.sohc4.net/index.php?topic=100525.0
Fishing is much more than fish. It is the great occasion when we may return to the fine simplicity of our forefathers.  ~Herbert Hoover
Offline nccb
  • 1974 CB750 Four
« Reply #5 on: April 10, 2012, 06:02:26 PM »
alright thanks guys.  I'll have to give it a look over this weekend.
Offline grcamna2
« Reply #6 on: April 10, 2012, 06:22:03 PM »
Just as has been said so far..clear the tiny return hole in the MC and then bleed the system..pump a little fluid through the bleeder valve on the caliper & get some fresh fluid in the system before you can determine if you need to take the caliper apart.
« Reply #7 on: April 10, 2012, 06:38:02 PM »
Assuming its the return hole, if you need to relieve the brake to push the bike, turn the bleeder valve and let some preesure out. Don't beat or lever the caliper. Put a rag or a hose over it as it may be under pressure (hence the sticking) and shoot out at you. Once you've done this, don't pull the brake lever again or you'll be stuck again.
