Author Topic: Exhaust - Studs or bolts?  (Read 1223 times)
Offline bmaker
« on: April 11, 2012, 07:28:28 AM »
Just finishing up a complete rebuild.  I have a new 4 into 1 and thought I would remove the studs to make it easier to put back in the frame and it offers a cleaner look.  Well after breaking 2 (i know many have felt my pain!) I am starting to reconsider.  Any thoughts on which is better or a matter of preference?
Many thanks
Re: Exhaust - Studs or bolts?
« Reply #1 on: April 11, 2012, 07:34:22 AM »
 It depends a lot on what pipes you can find.. spigot mount headedrs can be taken off in around 3 minutes or less, try that with stud/split collars..
Offline somesuch
« Reply #2 on: April 11, 2012, 08:47:02 AM »
The headers that use a stamped steel plate and studs for mounting to the head are much lighter than the headers that use spigot/collar arrangement.
Offline crazypj
  • I'm brill, me
« Reply #3 on: April 11, 2012, 08:51:46 AM »
Studs should be stronger and not wear threads in head.
 I would prefer to use them whenever possible
Offline stereosilence
  • 1975 CB550K
« Reply #4 on: April 11, 2012, 09:44:09 AM »
I replaced bolts with studs. Got them at ACE hardware. I was lucky that only one bolt broke off in the engine and it was far enough in that I could still put in the stud.
I screwing bolts in and out of the engine makes me antsy.
Offline bmaker
« Reply #5 on: April 11, 2012, 10:03:05 AM »
Using a Carpy 4 into 1.
« Reply #6 on: April 11, 2012, 10:17:25 AM »
 Spigots dont wear  threads in  the head, if using that type, studs is better than bolts..
Offline SohRon
« Reply #7 on: April 11, 2012, 05:18:49 PM »
Be sure to use some good copper anti-sieze on the new bolts/studs if you ever want to take them out again.
Offline bmaker
« Reply #8 on: April 11, 2012, 06:49:53 PM »
Thanks for the advice!  I think I'm going back with studs.  I feel so stupid!  If I just would have left the darn thing alone, I wouldn't have had to go to all this trouble with taking the old studs out.  They were in perfect shape. Live and learn I suppose.
