Author Topic: Cutting off fork gaiters/boots...  (Read 3482 times)
Offline 72BlackonBlack
« on: April 11, 2012, 01:42:19 PM »
What would the repurcussions be if I decided to cut off the fork gaiters/boots? Are they absolutely neccessary to protect and the keep the forks clean?
1976 CB550 Cafe (in progress)
1990 Yamaha Radian YX600 Fighter
1972 Ford Torino 472 BBF...
Offline LesterPiglet
  • 1977 CB550F2
Re: Cutting off fork gaiters/boots...
« Reply #1 on: April 11, 2012, 01:43:58 PM »
Why not just slip them off? You will need to replace them with smaller dust covers.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: April 11, 2012, 01:55:06 PM »
They help keep dust and dirt from getting on your forks and then on your seals.
Protects against road debris too.
  • 1977 CB550F2
« Reply #3 on: April 11, 2012, 02:09:59 PM »
They are also good at hiding a multitude of sins.
Offline singedebile
« Reply #4 on: April 11, 2012, 02:11:42 PM »
yeah, give them to me! mine have big cuts and rips in them
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
« Reply #5 on: April 11, 2012, 02:40:42 PM »
If you cut off and destroyed perfectly good gaitors, many would direct ire (or disgust) in your direction and perhaps question your intelligence.  ;) /jk
Fork seals last longest sliding over a smooth surface.  Stone chips in the chrome, dust & dirt, are all abrasive to both the fork metal and the lip seal rubber.  Dust and dirt you can keep at bay with daily wipe downs of the forks.  Stone chips can still happen.
The gaitors also keep water from pooling on top of the fork and rusting the seal retainers.  In 77 Honda switched to a dust cap on the forks to keep the water from pooling. But, this made the forks susceptible to stone chipping and dust/dirt accumulation.  It also made it easier to see when the seals started leaking.  ;D
To install the later dust caps, requires fork removal.  So, there is no need to cut off the gaitors, as they can be removed during that process of fork removal.  The upper fork chrome covers have a feature to capture the upper part of the gaitor.  This piece is exposed without the gaitors and some view that as unsightly.
Gaitors aren't "absolutely" neccessary for the next ride, but you might wish you had retained them on the 1000th to 10,000th ride when fork oil loss becomes an issue.
Then again if you have another method for keeping stones, dust, dirt, and water from getting at the forks, then of course gaitors aren't "neccessary".
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: April 11, 2012, 02:50:16 PM »
In my experience living in a wet climate, the fork seal are not good enough to keep water out of your fork oil so the gators are an added protection against water intrusion. The fork dust caps with the cone shape may help prevent this but without any protection water just sits on the fork seals and will eventually get past them.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #7 on: April 11, 2012, 04:44:32 PM »
Ok, so I really shouldnt remove the gaiters. I was mainly asking for cosmetic reasons because I am still questioning the aesthetics with the gaiters on.
Oh well, i just thought that might be a quick 30 second way to clean up the front end... Guess not... :-)
Oh well, onto other more important issues like cleaninh my carbs, finishing up rewiring some electrical stuff, installing exhaust... And oh yeah, getting the bike to run!
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #8 on: April 11, 2012, 04:57:11 PM »
Do what you want for cosmetic reasons. It's your bike. But frankly, I don't see many gators on modern bikes. Just bare chrome forks. I always thought gators were a "vintage" thing anyway.
  • 1977 CB550F2
« Reply #9 on: April 11, 2012, 05:06:28 PM »
I think it would break Health & Safety rules to carry gators on a bike.  :P
« Reply #10 on: April 11, 2012, 08:56:10 PM »
  Stock gaiters are not immune to letting water in, they are vented and have a few holes in them. Just look at how bad early forks rust under headlight ears, some of that water may get in the gaiters. Washing it can get it in there too.
 If you can live with the stock headlite ears minus the gaiters, you can pull the lowers off on 73 and later 750s, after popping the caps and springs.. but put the dust boots on, looks better. Worry about rock chips ?? most manufacturers havent for decades....
