Author Topic: Cb750 F front end  (Read 2276 times)
Offline eldar
Cb750 F front end
« on: April 12, 2012, 07:59:07 AM »
Does the 75/76 F front have the same geometry as the 75/76K, 77/78K of the f2/3 bikes? I dont have a manual with this specific info and digging something like this up is not always the easiest. I want to think they are like the 75/76K.
Offline BeSeeingYou
Re: Cb750 F front end
« Reply #1 on: April 12, 2012, 08:19:24 AM »
75/6 F  wheelbase 57.9 inches
            caster angle  28 degrees
            trail  4.5 inches
76K     wheelbase 57.3 inches
           caster angle 27 degrees
           trail  3.7 inches
Don't have specs for the others.
« Last Edit: April 12, 2012, 08:21:34 AM by srust58 »
Offline eldar
« Reply #2 on: April 12, 2012, 08:20:23 AM »
So would you say the wheel base on the F is slightly longer and at least as stable as the early K bikes?
Offline david 750f
  • 1976 CB750F
« Reply #3 on: April 12, 2012, 08:23:29 AM »
The offset on the triple trees is 50mm on the 75/76F's. This differs from the K0-K6 models which is 60mm.
1976 CB 750F
Offline BeSeeingYou
« Reply #4 on: April 12, 2012, 08:23:37 AM »
I would say the F bike is more stable than any of the K bikes and handles better.  Some of the contemporary reviews of the time state that.  Longer wheelbase and trail.
« Last Edit: April 12, 2012, 08:26:30 AM by srust58 »
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: April 12, 2012, 08:43:31 AM »
Yes, longer swing arm for sure, maybe more rake in the front.
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #6 on: April 12, 2012, 08:45:50 AM »
This is from a review from 1975 of the '75 CB750 f1 (Super Sport) in Cycle Magazine:
"However it may have been obtained—by the revised steering geometry, longer wheelbase, stiffer frame or whathave-you—the Honda CB-750F Super Sport does have exceptionally good handling qualities. Indeed, it is in this area that it comes nearest justifying the Super Sport label. The CB-750F, tighter gearing notwithstanding, is going to get shaded in a straight-line contest of speed with, say, a Z-1. But it handles better than any of the other Japanese Superbikes. Despite the longish wheelbase and stability-oriented steering geometry, the Honda CB-750F handles like a bike at least a hundred pounds lighter."
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline ChuckG750f1
« Reply #7 on: April 12, 2012, 08:54:49 AM »
Here's a link to the whole article quoted above:
http://www.motorcyclespecs.co.za/model/Honda/honda_cb750f_75.htm
- John Wayne
1976 CB750 f1
