Author Topic: Oil leak help  (Read 1441 times)
Offline Wingnut
Oil leak help
« on: April 16, 2012, 02:52:27 PM »
Recently changed oil in my 74 550. Picket up new o-rings thinking that would solve the leak where the filter housing and case come together....nope....still leaking.
Do I have a bigger problem? Am I missing something?
Thanks
1974 CB550
"Yeah, well, sometimes nothin' can be a real cool hand."
Offline Johnie
Re: Oil leak help
« Reply #1 on: April 16, 2012, 05:08:41 PM »
Did you use a OEM filter or aftermarket?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
bollingball
Re: Oil leak help
« Reply #2 on: April 16, 2012, 05:12:35 PM »
Did you change both o-rings?
Ken
Offline Wingnut
Re: Oil leak help
« Reply #3 on: April 19, 2012, 08:16:55 AM »
Changed both o-rings, used an aftermarket filter. Looks exactly like the old filter I pulled out. Could be that the oil leak started when the previous owner used aftermarket parts as well? Could I fix the problem with an o-ring that's a bit thicker?
1974 CB550
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Oil leak help
« Reply #4 on: April 19, 2012, 10:23:25 AM »
It shouldn't leak at the filter housing unless the o-ring or the filter casing is cracked or knicked or warped. That's the one place I've never had a leak after quite a few oil changes. And I use aftermarket as well as OEM filters it should have nothing to do with the housing leaking. Can you snap a pic of exactly where it's leaking? Have you tried thoroughly cleaning the area to see where it's leaking from? You might be surprised at the source.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Johnie
Re: Oil leak help
« Reply #5 on: April 19, 2012, 01:53:34 PM »
I have heard of some aftermarket filter gaskets to be a bit thin. Find a friend with a used Honda gasket and swap it out. Or go to your dealer and buy a new filter and give it a try.
Oshkosh, WI  USA
Offline Wingnut
Re: Oil leak help
« Reply #6 on: April 26, 2012, 12:58:02 PM »
Well it turns out that the o-ring that came with the new filter was a bit too thin. Really easy fix though. Went to the local NAPA store and picked up another o-ring the same diameter but just a bit thicker, fixed it right up.
Thanks for the help
1974 CB550
Offline Johnie
Re: Oil leak help
« Reply #7 on: April 26, 2012, 05:34:14 PM »
Glad you got it sorted out. Those aftermarket filters do cause some issues.
Oshkosh, WI  USA
Re: Oil leak help
« Reply #8 on: April 26, 2012, 11:37:46 PM »
you also dont need to do the bolt super tight,it should just compress the ring then a little more.
