Author Topic: I need 4 sets of std. bore 1978F2 rings......  (Read 2499 times)
« on: June 07, 2006, 12:27:27 PM »
 I've already tried Silver Spares(they have 1 set), CMSNL, Western Hills. They are discountinued from Honda. Figures they are the only friggin 61mm bore rings to use a 1.2mm top ring..... just for 2 years!  79/80 750 DOHC use the same 2nd and oil rings but the top ring is 1mm. I'll have to call Total Seal otherwise. F2's are a nightmare sometimes ::)
Offline scondon
  • Mmmm......tasty bugs
Re: I need 4 sets of std. bore 1978F2 rings......
« Reply #1 on: June 07, 2006, 01:29:31 PM »
    Mike, let me know if you need anything else for that engine. I've got one on the stand and will be using only the towers/rockers. Nice cam with only 12 grand on it on the shelf as well.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: June 07, 2006, 02:42:43 PM »
Could you replace with a set of pistons and rings from a different year 750?  Something a little more common?
« Reply #3 on: June 07, 2006, 02:59:00 PM »
I would have to replace the head as well (which I just reconditioned). F2 pistons have a higher dome to compensate for the larger combustion chamber.
Offline jtb
  • An unlikely
« Reply #4 on: June 07, 2006, 03:22:22 PM »
Sean,  I might need your cam.  depends upon finding rings.
John
1977 CB750F
1985 V65 Sabre
Offline scondon
« Reply #5 on: June 07, 2006, 04:11:15 PM »
John
  It's on the shelf if you need it John. Good luck with the rings.
   I know this probably won't help but KaceyF2 was selling his .25 over pistons and rings a while back(UK). Might still have'em.
shinysideup
« Reply #6 on: June 07, 2006, 08:51:48 PM »
dunno if you'd be interested, but i am seriously considering parting out or selling my 78- 750f2-
can't keep pouring the money into her.
got lotsa good parts- the original muffler is still shiny even.
Offline Clyde
« Reply #7 on: June 08, 2006, 03:44:36 AM »
Mike,
The 75 F used the thicker rings and so did the 76 F1 initially. From Eng-no 2551568 onwards the later F1 pistons used the thinner rings Part number 13011-392-004.
I am not sure if this is the number you're looking for
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #8 on: June 08, 2006, 10:09:01 AM »
Mike,
Regds Clyde
I will check on it Clyde. Thanks for the info...I appreciate it!
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #9 on: June 08, 2006, 08:04:06 PM »
G/day Mike. I had the same problem about 18 months ago. I searched everywhere for a standard set of rings for weeks. I was
ready to give up and go for over size pistons and rings, which were available, when a set of standard pistons and rings came up on ebay. I made sure that I won that auction! This story doesn't help you at all but it might make you feel better knowing that you aren't the only one that has had trouble. Good Luck, Pat
Regards
Pat from Australia
upperlake04
« Reply #10 on: June 09, 2006, 08:40:46 AM »
 Mike  - I was at Custom Cycle here in Saskatoon this morning and inquired about standard rings for 1978 CB750 F2s.  The parts guy says they are available from the distributors in both Toronto and Vancouver and would take about a week to get here.   Part number 13011-392-004   $34.06Cdn/set
« Reply #11 on: June 09, 2006, 09:13:03 AM »
Thanks David....Clyde gave me the same info the other day. I'm going to the shop taday and will check the number. Thanks again guys!
  Mike
Offline jtb
  • An unlikely
« Reply #12 on: June 09, 2006, 01:09:11 PM »
That's the right number, Mike.  I've been calling around here to see if anyone has any.
John
1977 CB750F
1985 V65 Sabre
« Reply #13 on: June 09, 2006, 02:07:14 PM »
John
All set John....I ordered 4 sets today. And once again thank you Clyde and Dave. I've helped Dave out a couple of times but if I can be of service Clyde let me know. ;)
Offline jtb
  • An unlikely
« Reply #14 on: June 09, 2006, 02:25:11 PM »
Clyde and Dave,  Thanks from me, too.  It's my engine.
John
1977 CB750F
1985 V65 Sabre
