Author Topic: How can I tell if clutch or rear wheel is slipping - CB750???  (Read 4512 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
I have a sorta fast CB750 836 geared 17-48. If I'm running at about 4800rpm and nail it in fifth, it feels like the engine is revving slightly as the bike lunges forward. I'm familiar with slipping clutches as the tach needle will jump when that happens with accompanying noise and no acceleration so it doesn't behave like a slipping clutch. It is like the rear wheel is breaking loose but that's what sport bikes do - right? Not 40 year old Honda's. It's kinda a hard to believe that's what's happening but I thought I'd ask the hot-rodders in the group. Or maybe someone can provide some insight.
Offline GammaFlat
Re: How can I tell if clutch or rear wheel is slipping - CB750???
« Reply #1 on: April 17, 2012, 05:48:18 PM »
Are you asking a question or just trying to make folks with less horespower feel bad?
In any case, it seems that you're making a lot of power.  Is that correct?  Is that a bad thing?  Yee Ha!
Keep us posted :)
K6
85 Goldwing
« Reply #2 on: April 17, 2012, 05:49:52 PM »
Loud exhaust?
Offline mycb750k6
  • Rocketman
« Reply #3 on: April 17, 2012, 07:05:55 PM »
Ahhh, no. Stock HM300s. And I really don't know what's going on but would like to know if I have a clutch problem or not. Oil is Castrol 20/50 4T motorcycle oil and clutch adjusted 1/8, 1/4 and everything in between. So is spinning the tire really possible in this scenario? Seems unlikely.
Offline the technological J
  • deliciouso!
« Reply #4 on: April 17, 2012, 07:15:36 PM »
my money is on clutch slippage.. maybe  pull the clutch and scatch up the sufaces a little... maybe through some hd springs for good measure
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #5 on: April 18, 2012, 12:48:23 AM »
I often see Motogp bikes leaving a black trail of rubber in high gears when I'm watching the telecast, but these machines of upwards of 200 horsepower.
I think really that if your bike is capable of wheelspin in 5th you would be lighting the back tyre up every time you hammered it in the lower gears as well.
Time to think clutch methinks.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #6 on: April 18, 2012, 01:22:52 AM »
+ 1 Frosty, if that bike spins the tires in 5th then i want it...... ;D
« Reply #7 on: April 18, 2012, 03:47:32 AM »
Either your clutch is slipping mate, or there's oil all over the road. (you're not riding on loose gravel are you?) There's a right way and a wrong way to reassemble a clutch assembly, if you don't get it right, it doesn't matter how well adjusted it is, it'll slip. Did you reassemble the clutch, or was it a PO?
Anyway, short of your clutch discs being worn out, I'll bet it's been put back together incorrectly. The only bike I've had that will spin the back wheel in top gear at 60+ MPH is my Triumph Rocket III, but it's got 3 times the rear wheel BHP and 4 times the torque of a CB750. Cheers, Terry. ;D
Offline KJ790
« Reply #8 on: April 18, 2012, 04:25:29 AM »
Hit your back brake while you peg the throttle in 5th gear. If it still feels like it is slipping then it is your clutch.
Offline mycb750k6
  • Rocketman
« Reply #9 on: April 18, 2012, 08:02:04 AM »
OK thks. I'll do some more informative and useful tests.
Terry, is it true that the wheels spin clockwise in OZ?
Offline Dyrden
« Reply #10 on: April 18, 2012, 08:30:48 AM »
+6 on slipping clutch.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #11 on: April 18, 2012, 10:11:57 AM »
clutch
Offline mec
« Reply #12 on: April 18, 2012, 03:10:25 PM »
you are riding on snow or ice? then its the rear wheel (836, CR, hot cam,....)
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #13 on: April 18, 2012, 07:10:44 PM »
Had a similar problem. I fixed it by installing new clutch springs.  8)
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
bollingball
« Reply #14 on: April 18, 2012, 08:11:03 PM »
Put the front tire against a tree in gear and see if you can make it slip. Rear tire must be on hard surface.
« Last Edit: April 20, 2012, 03:51:01 AM by bollingball »
« Reply #15 on: April 19, 2012, 12:29:24 AM »
Hmmnn, that's an intriguing question mate, I'm glad you asked. If I look at my front wheel as I'm riding along it turns clockwise if I look from the points cover side, but anti-clockwise if I view it from the alternator cover side? I've got no idea what the back wheel is doing, because my tiny brain can't cope with me looking backwards as I go forwards, so I avoid trying at all costs!  :o  :)
Offline hockeyteeth
  • bicycles and motorcycles
« Reply #16 on: April 19, 2012, 08:17:21 AM »
Yeah, I once bought new fiber plates for a slipping clutch only to notice how weak the original springs were when I replaced them. The original fiber plates didn't look burnt at all, so I bet it was just the springs in my case...
Previously Owned - 1971 CB750 K1
Offline phil71
« Reply #17 on: April 19, 2012, 08:27:10 AM »
Breaking the rear wheel loose in 5th? I'd say the thing that's slipping most is the grip on reality. Check that first.
« Reply #18 on: April 20, 2012, 12:49:17 AM »
Will stronger springs improve your grip on reality Phil? ;D
Offline trueblue
« Reply #19 on: April 20, 2012, 01:33:59 AM »
I can verify that changing to a non-synthetic oil improved my grip on reality, but I could still use some stronger springs I think.
1979 CB650Z
« Reply #20 on: April 20, 2012, 01:59:21 AM »
i would expect easy front wheel lift in first/second and third if you can spin it in top gear?
Offline excellrec
« Reply #21 on: April 20, 2012, 10:48:59 AM »
If your clutch springs are old maybe just get new ones.  Heavy duty springs will work but it comes at great cost in the feel of your clutch.
