Author Topic: this has got to be wrong... oil adapter  (Read 5515 times)
Offline Elan
    • Vital Motor Parts
« on: April 18, 2012, 04:43:36 PM »
ok I just got my ebay vintage oil adapter in the mail. THe seller said it was for an sohc cb750, and had a lockhart radiator that he ditched. BUt I don't see how this could work... am I missing something or did the seller mis label what he was selling??
Heres what I got...
First off, the adapter center hole sits quite loosely on the motor. Notice the 1/8" gap between the adapter hole and the oil galley...
Second, my oil bolt threads into the female end of the adapter bolt, the the male threads of the adapter bolt are much too large for the engines oil galley threads.
Third, The adapter bolt wouldn't hold the adapter anyway, because the entire thing is smaller than the hole....
SO am I missing something or do I need to package this thing back up?  It seems I could use it if I had the proper bolt?
ugh.
« Last Edit: April 18, 2012, 04:48:23 PM by Elan »
76 750k
Offline onepieceatatime
Re: this has got to be wrong... oil adapter
« Reply #1 on: April 18, 2012, 06:16:22 PM »
The adaptor bolt is quite difficult to track down. I bought one for my '80 cb650 that the hole is at least the right size, but no adaptor bolt for it. My solution was to get a '83-'85 cb650 filter cover because it is shorter and just use my original bolt, which is longer than the 750 bolt. I would still like to find the correct adaptor bolt, but am not counting on it. I don't think my solution will work in your case though. I think someone on the site makes (or made) adaptors for the 750s you may be able to find something when the search is working.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #2 on: April 18, 2012, 09:19:16 PM »
 Measure the diameter of the hole and thickness..maybe we can make one..
Offline Killer Canary
  • Typical Bran Muffin
« Reply #3 on: April 19, 2012, 08:04:19 AM »
I've got a couple of adapters and bolts I machined myself; one's on my 550 and the other's a spare. I would sell you the bolt but I doubt that the designs are the same. Terry would probably machine one for you for a decent price. Or just send the damned thing back.
Kawi GPz900, H1
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: April 19, 2012, 08:06:09 AM »
Would a spin on paper element filter work without the adaptor or original bolt?
Offline Elan
    • Vital Motor Parts
« Reply #5 on: April 19, 2012, 08:12:36 AM »
pretty sure thats a no, for reasons I cant remember. Theres threads on that subject.
76 750k
« Reply #6 on: April 19, 2012, 08:15:41 AM »
The filter end of the bolt would be male and have imperial threads.
Kawi GPz900, H1
Offline Elan
    • Vital Motor Parts
« Reply #7 on: April 19, 2012, 08:17:48 AM »
Or maybe you can send those pictures and the cooler back to the seller and request your money back..... ;)
Yeah I sent him an email. Ill see what he says.  If i get a bolt made, this old setup will end up costing more than a new one.  I actually pm'd terry asking if he still made them, and didnt hear anything back. I might try again as I dont completely trust the system( or that I clicked the send button).
76 750k
« Reply #8 on: April 19, 2012, 08:32:12 AM »
 check if seller maybe has other nut....  that looks like a good adapter, some are worse looking. if you need one, you decide what is worth doing next.
 I am not a fan of the spin-ons.
 costing more than a new one ?? did not know they make new ones.
« Reply #9 on: June 09, 2012, 09:25:12 PM »
I took a chance and bought this on ebay: 1986 YAMAHA FZ600 OIL COOLER ADAPTOR BOLT
It is a discontinued part.
This is OEM information for the part:
BOLT,UNION
90401-20089-00
Here are other bikes it was used on.
http://www.boats.net/parts/detail/yamaha/Y-90401-20089-00.html
My plate looks like this:
If you cannot find one on ebay, I found this forum with reproduction ones advertised:
http://xjbikes.com/Forums/viewtopic/t=14561/postdays=0/postorder=asc/start=15.html
Their part number is : HCP3165. it is about 2/3 of the way down the page for around $20.
I did a test fir on my spare engine case, without the filter element, and it seems to work fine. I have yet to test it with the filter element, but if it will not go together, I can grind a little length off the head to make it shorter.
I think the adapter bolt the OP has is for a DOHC CB750.
« Last Edit: June 09, 2012, 09:35:02 PM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Elan
    • Vital Motor Parts
« Reply #10 on: June 11, 2012, 09:54:30 AM »
Good to know thanks! 754(above) is machining one for me.
76 750k
bollingball
« Reply #11 on: June 11, 2012, 10:56:16 AM »
Rigid you would need this adaptor bolt for a spin on car type filter on our sohc motors the short threads go to the filter I don't know the Wixs # off hand.It is a common filter but orange would not go with my bike. ;D
Ken
Offline CycleRanger
  • No comment about being an
« Reply #12 on: June 11, 2012, 11:16:42 AM »
Rigid you would need this adapter bolt for a spin on car type filter on our sohc motors the short threads go to the filter I don't know the Wix # off hand.It is a common filter but orange would not go with my bike. ;D
Ken
Some additional info about that here:  http://forums.sohc4.net/index.php?topic=86770.0
Wix # 51390
bollingball
« Reply #13 on: June 11, 2012, 11:29:49 AM »
Ken
Wix # 51390
I forgot all about that post last year
