Author Topic: CB750 MPG seems bad. Running rich or gas leak?  (Read 5622 times)
Offline boots
« on: April 19, 2012, 09:32:33 AM »
My cb750 k7 got 28 MPG on its last tank. That seems darn wrong.
I can't recall what mileage I was getting last season.  I've noticed a small drip from the output of a new fuel petcock when in the stop position, could this be the culprit? But I don't ever see that fuel has run out of the carbs when it's parked, which is where it would go if the drip is pushing fuel through the whole system.
I'm running a 4-into-1 pipe with a baffle (which is new to the bike, the old pipes were 4-into-2 no baffle), a stock air box and stock jets.  Mixture screws are turn 1 1/2 out from completely closed, idle speed is proper. Could my new pipes be affecting the mixture?
Any thoughts on diagnosing this? Or better yet, what mileage do you think I should be getting?
Offline Really?
Re: CB750 MPG seems bad. Running rich or gas leak?
« Reply #1 on: April 19, 2012, 10:18:59 AM »
I wonder if your mileage is fine but you are not using the fuel as you think?  Leaking petcock, fuel coming out of overflows when parked overnight or down the carbs and into the cyl's and into the oil sump?
If you pulled the fuel line, with the petcock off, at night.  See if anything came out in the morning?
Dunno, just thinking.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline lrutt
« Reply #2 on: April 19, 2012, 10:42:29 AM »
man, that is bad. my k6 will get 50 or a little better all day long. my k8 with sidecar 45.
Offline curemode2002
« Reply #3 on: April 19, 2012, 10:46:00 AM »
I had a drip from the petcock on my cb650 that was dropping my MPG about 11 MPG new petcock got that all resolved now I am back to 42-45 MPG. I even shut mine off every night before and after but that pesky leak killed me even though it was just a slow drip.
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline boots
« Reply #4 on: April 19, 2012, 10:47:39 AM »
Yeah, you guys are probably right. It's way too bad not to be a leak. I'll be pulling the petcock and seeing what's what with that drip.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #5 on: April 19, 2012, 11:53:33 AM »
maybe check the oil level / sniff the oil?
searching for a dr350se
Offline dhall57
« Reply #6 on: April 19, 2012, 03:08:50 PM »
Take a look at your front brake caliper also and make sure brakes aren't dragging. My 750K6 was doing that and I was getting 25 mpg on hwy. Fixed that and now gets 50 mpg. ;D
« Last Edit: April 19, 2012, 03:24:32 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #7 on: April 19, 2012, 05:26:34 PM »
You may have a leak and not know it. I have noticed that this ethanol fuel dries very fast compared to real gasoline.
Offline hman0217
« Reply #8 on: December 07, 2016, 09:30:13 PM »
would one feel the drag of the caliper in this case? I certainly don't feel a loss of power but i just filled up my tank and calculated 19 mpg on the last tank. sheesh...
« Reply #9 on: December 08, 2016, 05:18:43 AM »
Put it up on the center stand if you have one or a jack and see if it has any drag. Also if you have a drag the disc and caliper will be hotter than normal when being used. As for mileage 45-50 mpg is normal for me on the stock 750's.
« Reply #10 on: December 08, 2016, 06:35:50 AM »
When was the last time you did a complete tune-up?  (Pay special attention to timing/advance and a proper vacuum sync of your carbs)
How do your plugs look after riding?
What do they look like after an idle plug chop?
Offline ofreen
« Reply #11 on: December 08, 2016, 07:03:24 AM »
Looks like the OP is long gone.
Greg
'75 CB750F
« Reply #12 on: December 08, 2016, 07:24:31 AM »
Hahahaha....Thanks for diggin' up an old one, hman0217  ::)
Offline hman0217
« Reply #13 on: December 08, 2016, 11:12:04 AM »
Well I didn't want to get yelled at for asking a question without trying the search tool first!
Well tried that and that wasn't it. Thanks though
« Reply #14 on: December 08, 2016, 02:35:12 PM »
 Old crusty dirty aged stock paper filter won't help the mileage either if you have the stock air box.
« Reply #15 on: December 08, 2016, 04:40:54 PM »
I had a similar problem  with my K4..usually got about 20 mpg.., had them apart many times..had one plug that would foul once in a while and need clean/replace.
 Sometimes when iI took a left turn lane in warm weather and I was idling, I could see folks in cars fanning their face..the fumes were that bad.
 Then one day i threw another set of roundtops on , sealed a few leaks/weeping..and away it went 40-55 mpg..
 I can only surmise it had bad brass parts..
Offline hman0217
« Reply #16 on: December 16, 2016, 08:29:04 PM »
pardon my ignorance...what are you calling a roundtop?
« Reply #17 on: December 16, 2016, 10:00:47 PM »
What year is it? 750 i presume...69- 76 has roundtop carbs...look in for sale for pic
77-78 has PD carbs or coffin tops they are sometimes called..
Offline hman0217
« Reply #18 on: December 17, 2016, 06:37:55 AM »
yea it's a '75 K5, so  guess I have roundtops. Just rebuilt them too. One thing...the boots from my carbs to the engine are the originals and I have reason to suspect they may be leaky because of two symptoms:
1. sometimes after the bike warms up the idle stars climbing dramatically. I've mitigated this by setting the idle low and holding the throttle when I cold start so the high idle is actually a good idle.
2. Occasionally,the engine loses a bit of power suddenly and the revs seem to drop (from the sound of them)
So I think I'll try that, since you pointed to carbs/leaks as a reason for getting crap efficiency.
Thanks
« Last Edit: February 12, 2017, 10:00:11 AM by hman0217 »
