Author Topic: A day's work: Before and after!  (Read 2422 times)
Offline Gordon
  • 750K1, 550K2
« on: June 08, 2006, 05:26:59 AM »
What a difference a little paint and a set of clubmans makes. :)  I know the flat black thing is sort of cliche at this point, but what can I say?  I like it!  After I finished yesterday, I stepped back to look at it, and for the first time really felt like it was mine.  I have a feeling the 750 is going to be getting a well-deserved break for a while! ;D
Now all that's left is to put on a larger rear sprocket, smaller turn signals/brake light, and maybe a 4-1 or 4-2 exhaust.
Offline sparty
  • I just play one on TV
    • Gallery
Re: A day's work: Before and after!
« Reply #1 on: June 08, 2006, 05:39:47 AM »
Gordon,
I like the new look.  "I like it alot".
How was the paint laid on?  Did you do it yourself?  Looks good in the pictures.
That bike has some attitude now.
1972 CB750 K2 Cafe' Style
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 08, 2006, 05:53:34 AM »
Thanks!  That's a rattle can job, there.  Stripped the tank with aircraft paint stripper, four coats of primer, wet-sand with 400 then 800.  Three thin coats of flat black, wet-sand with 800, then one thick coat over the whole thing.  Then two thin coats of flat clear-coat, and one thick coat.  It's all in the prep work! ;D
Offline sparty
    • Gallery
« Reply #3 on: June 08, 2006, 06:02:44 AM »
Did you have to repair any "dings", "rust", etc.?  I didn't realize you could get a rattle can paint job to look so good.  What brand of paint?  By the way, flat black is still cool.  My new paint job is going to be sick.  It will combine flat and gloss paints.  I was thinking of having it pro-painted until I saw your outcome.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: June 08, 2006, 06:10:32 AM »
Nope, luckily other than the extremely faded stock paint, the tank was in perfect condition.  I have done bodywork on tanks before, and it's pretty easy.  You just put on more filler than you need and then sand it down until it matches the contour.  The key to any kind of bodywork or painting is patience, regardless of whether you're using a rattle can or pro style spray gun.  If you try to go faster than the paint wants to, or skip any steps, it will look like crap.
Offline 78 k550
« Reply #5 on: June 08, 2006, 06:11:52 AM »
Look's great Gordn,
 You riding the 750 today or the 550?See ya in about an hour.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #6 on: June 08, 2006, 07:29:24 AM »
GORDON--->
That bikes looks mean  ;D
Def. headed in the right direction, thats 4 sure.
One I get my bike back I plan to strip the tank and re-don my flat paintjob, def. using some sort of "flat" clear.
Exactly what products did you use for you tank (brand wise) ?
Offline Rushoid
  • Shameless
« Reply #7 on: June 08, 2006, 08:42:19 AM »
Killer look Gordon!
BTW, I think your bike is haunted now. Looks like you captured an "orb" in the second pic!  :o ;D
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #8 on: June 08, 2006, 09:01:02 AM »
I like the bobbed front fender - how does one get such a neat cut in chromed steel and then protect the leading edge from rust?
eldar
« Reply #9 on: June 08, 2006, 11:13:55 AM »
just an idea for you gordon, take off the little back brace on the front fender. I did that and I was amazed at the diffence in the look. I have not had an issue of the fender rubbing the tire either.
Offline martini
« Reply #10 on: June 08, 2006, 12:16:41 PM »
Looks awesome :) - I'd also love to hear how you cut that front fender. For what its worth, if I were you I'd leave those pipes as is. Probably just me but I've always loved the look of those 550 pipes. 8)
upperlake04
« Reply #11 on: June 08, 2006, 12:33:18 PM »
Hope you had a great ride Gordon!
Paint job looks great,  I think thats the color and gloss for my old F.  A question please  - how much time did you allow between coats?      David
Offline cben750f0
« Reply #12 on: June 08, 2006, 05:19:03 PM »
well done mate you should be proud.... and flat black never goes out of fashion..peace
Offline KCs76Cafe
  • Jackson Creek,NC..Deep in the stix of the TRIAD
« Reply #13 on: June 08, 2006, 06:27:45 PM »
Looks real good. A days work well done.
 I like the bobbed fender also. I've cut about 4" off of the back of mine........will probally do the front as well.
I used an old fender to mark for the cut using a Dremel with a thin cut-off wheel. Gave me the same radius as stock. Hit the edges with a buffing pad to clean the burrs and then touched it up with silver paint. You cant hardly tell it was cut.
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: June 08, 2006, 07:42:52 PM »
Hey!  Thanks for all the kind words! :)
ProTeal, I just used Rustoleum rattle can paint, primer, flat black, and flat clear.
Rushoid, that orb's been following me all my life!  This is the first time I've caught it on camera.  I'll be selling this picture to the Weekly World News, so keep an eye out for it.
Tintin, I cut the fender with a dremel cutting wheel, and I didn't do anything to protect the cut edge, but I probably should.  That was sort of a circumstacial mod.  The front edge and front fender struts were pretty messed up when I got it, so I just cut it off, and then decided I actually liked the look.
Eldar, I thought about cutting a few inches off the bottom of the fender and getting rid of the other struts, too, but didn't know if I would have problems with the speedo cable rubbing on the tire.  How did you get around that?
Upperlake, since it was about 95 deg while I was painting, I only waited about 5 minutes between coats.  The paint drys really fast at that temp and low humidity.  The last two thick coats I waited about 15 min.
upperlake04
« Reply #15 on: June 08, 2006, 07:59:02 PM »
thanks Gordon -  sounds too easy
Offline pablo78cb550
  • mmmph.
« Reply #16 on: June 08, 2006, 08:41:12 PM »
yes flat black is always cool.but i gotta tell ya three words.
'bar end mirrors' in black.
mmmmmmmm
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline Gordon
  • 750K1, 550K2
« Reply #17 on: June 08, 2006, 08:47:11 PM »
mmmmmmmm
Not with the clubmans!  I had the bar ends on the clubmans when I had them on my 750 for a short while.  They were worthless way down there at that angle.
Offline cben750f0
« Reply #18 on: June 08, 2006, 09:29:50 PM »
mate havent you worked it out yet  function is nothin, appearance is everything.... ;D..peace
