Author Topic: OIL on a clean engine: 750 k4 tach cable leak  (Read 2982 times)
Offline andrewraffaele
« on: April 21, 2012, 10:48:27 PM »
Dear all,
Oil is bleeding out of my valve cover where the tachometer cable plugs into the engine. I'm riding a 1974 CB750, 13k miles and a super clean engine otherwise... any way I can keep her a little more tidy?
Thank ya,
Andrew
Offline dhall57
Re: OIL on a clean engine: 750 k4 tach cable leak
« Reply #1 on: April 21, 2012, 11:38:10 PM »
Just replace the tach seal. Honda still has them, but use the one for early dohc 750 instead of the sohc seal. It's a fraction larger so it seals better. I've had to replace both on my 750KO and K6.
« Last Edit: April 22, 2012, 07:11:43 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline cookindaddy
  • I sure love this bike!
« Reply #2 on: April 22, 2012, 04:45:44 AM »
Happened to me also. Using the Honda seal for the SOHC works fine, no oil leakage here after I replaced mine.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline thrutheframe
« Reply #3 on: April 22, 2012, 06:22:40 AM »
Ditto... The hardest part is getting the screw out.  If the screw looks boogered just order the screw when you order the seal,  little touches like that go a long way.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Roach Carver
« Reply #4 on: April 22, 2012, 01:10:08 PM »
Well, im a moron. Ive never replaced one but I have a leak in one engine. I pulled the tach cable and saw no seal. I just figured it was inside the valve cover as that is my usual luck. Where is it????!
Offline dhall57
« Reply #5 on: April 22, 2012, 04:08:52 PM »
I guess its possibly yours is missing. If the leak is bad that would explain it. The seal is recessed in the valve cover maybe a 1/2" or so get a flash light and be sure its in there and see if you see the top of the seal. It can be a little tricky getting it out so I get a very small drill bit and drill very carefully into the top on one side of the seal. Don't go very deep into the seal just enough so you can screw a small screw into top of seal. A couple turns is all it takes. Than take some needle nose pliers and grab the screw an pull the seal out.
« Last Edit: April 22, 2012, 04:23:25 PM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Pecantree
« Reply #6 on: April 22, 2012, 05:49:38 PM »
You can also take a 2" or so drywall screw and screw it into the rubber of the seal and pull it out with pliers.
Also use a socket, I think 9mm to seat the seal.
I've "heard" of someone thinking the seal was gone and installing a second seal on top of the first :o
I'd never heard about the dohc seal. I'll have to do that next time.
Good Luck
Steve
« Reply #7 on: April 22, 2012, 09:22:44 PM »
Good Luck
Steve
On my 750K4 I looked in the hole three times but never saw the seal.  Its hard to see down in there.  I didnt quite install the second seal but it was close.  Stick a pick tool in there and probe around, you'll be able to tell solid metal from a rubber seal.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
