Author Topic: No spark, now have spark VIDEO!!!  (Read 1390 times)
Offline Tews19
  • I am no
« on: April 22, 2012, 06:47:03 PM »
I installed my new dyna coils with plugs on my 1975 550F.. Followed all the instructions which were #$%*ty... went to Youtube and followed the video. Everything is installed correctly......No spark.... Bike has power.... all wires are hooked up.... Now my lights in the gauges only turn on when I am engaging the clutch... As well as the headlight. It only turns on when I have the clutch engaged. I let go on the clutch and the lights turn off. Also, the high beam light turns on with clutch engaged as well.
I tried the clutch engaged to see if i have spark... No spark.... Am I missing something here? been since last summer since I had the 550 running so I have forgotten if I have a safety switch like some bikes... Pretty sure this thought is a no though....
Any help would be great.
« Last Edit: April 23, 2012, 04:21:47 PM by Tews19 »
1970 Honda CB750 survivor.
Offline scunny
  • don't call me expert
Re: No spark, running lights on when clutch engaged
« Reply #1 on: April 22, 2012, 06:52:24 PM »
certainly sounds like you have hooked up to the "clutch safety"
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Tews19
  • I am no
« Reply #2 on: April 22, 2012, 06:57:58 PM »
can someone guide in to the right direction?This beast is ready to ride............Minus this issue
« Reply #3 on: April 22, 2012, 08:41:54 PM »
Since those coils aren't really new, I would test those first (google it).
Why did you buy those coils, were the stock coils bad? If yes, maybe it's not the coils??
Offline thrutheframe
« Reply #4 on: April 22, 2012, 09:16:55 PM »
Really sounds to me like you have the clutch safety circuit run to the headlight, which would in turn mean the coils are being grounded out and not sparking.  Revisit your wiring diagram.
  Did you meter the black w/ white wire going to your coils?
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Hush
« Reply #5 on: April 22, 2012, 09:43:12 PM »
I'm with Scunny and Thrutheframe on this, somehow you have hooked up to the clutch safety over-ride circuit.
Better check the wires from the clutch swith (up under the lever) and trace them back to where they should go. :)
Offline Tews19
  • I am no
« Reply #6 on: April 23, 2012, 05:08:02 AM »
I was thinking the two wires that were attached to the clutch handle as well. I trace them and both are inside the headlight bucket and connected to their matching wires. Tonight I will see where they go.
To clarify though- this 75 550f does has a clutch safety override circuit?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #7 on: April 23, 2012, 12:25:39 PM »
That would be the two wires coming from the clutch lever. They should be Green/red and green.
Offline Tews19
  • I am no
Re: No spark, now have spark VIDEO!!!
« Reply #8 on: April 23, 2012, 04:24:54 PM »
I figured out why I have no spark... I kept looking at the points today as member Mike Kato gave me some advice... Then I noticed two wires tucked underneath the airbox.. Yellow solid and blue solid.  PLugged them in and here she roars for the first time since I tore her down over the winter!!!!
Thanks to all of you gave me clues.. I still need to figure out the wiring.. I hooked up all the wires properly but blew a fuse when hooking up my aftermarket signals.
http://s1090.photobucket.com/albums/i373/Tews19/?action=view&current=018.mp4
  • 1977 CB550F2
« Reply #9 on: April 23, 2012, 04:27:09 PM »
I was a bit worried there when I seen the painted toenails.  ;D
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: April 24, 2012, 01:47:43 PM »
Sounds awesome Tews!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
