Author Topic: removing powder-coating  (Read 1177 times)
Greg
« on: June 08, 2006, 05:27:15 PM »
so a while back i blasted and poweder-coated a tank - the sand blaster #$%*ed up, coated inside, the metal was too weak, ended up with lots of holes, etc.
so i decided to cut the thing up and weld some knee inserts. so now i need to get rid of all that pwdercoating. is sand blasting my only option?
thanks guys!
greg
Offline Bob Wessner
  • "Carbs Suck!"
Re: removing powder-coating
« Reply #1 on: June 08, 2006, 05:38:46 PM »
Take a look at this. If you scroll down, there is one paragraph re: removal. The rest is about the process in general. Good luck, let us know how it goes.
http://my.execpc.com/~davewrit/Powder.html
Offline kghost
« Reply #2 on: June 09, 2006, 04:10:13 PM »
Believe it or not.....Paint stripper takes it off....
Don't cheap out
Buy the good stuff and let it sit.
Stranger in a strange land
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: June 09, 2006, 04:17:58 PM »
I wondered if that would work. In reading about the process, it's described as paint powder (pigment?) that's baked on.
