Author Topic: Misalanious steel ball???  (Read 1382 times)
clzay
« on: June 08, 2006, 06:05:57 PM »
Hello I have a 78CB550 and I planed on replacing my woren clutch this this afternoon. Well everything went well I replaced the steel and friction plates and added four new springs. As I was installing everything back together I noticed a little steel ball laying in the clutch cover. Now this steel ball is similar in size to the "clutch lifter rod" which has round balls on either end, but I have no clue to where this steel ball goes??? I'm read my Clymer manual, but still haven't figured this out, and I tried installing the clutch with out it, but theres way to much play in the cable? Has anyone installed a clutch on a cb550 and might know where this steel ball goes to get my baby back on the road?
Offline Jonesy
  • Shop Rat
Re: Misalanious steel ball???
« Reply #1 on: June 08, 2006, 08:12:18 PM »
Does your clutch lifter rod have the balls intact on each end?
Offline Noel
« Reply #2 on: June 08, 2006, 08:27:27 PM »
"Are the balls on your rod intact?" *snicker*
'73 CB500
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #3 on: June 08, 2006, 08:48:07 PM »
Hmmm, I'm not sure, but it kinda does look like the clutch lifter arm - #11 - does has two little balls showing at either end.  Kinda fuzzy picture though.  As I've never torn into my clutch, I can't help you much more.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline csendker
« Reply #4 on: June 08, 2006, 09:03:52 PM »
And here's the Clutch pages from my shop manual...p40...
Offline csendker
« Reply #5 on: June 08, 2006, 09:04:14 PM »
...41...
Offline csendker
« Reply #6 on: June 08, 2006, 09:04:36 PM »
...and 42.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #7 on: June 08, 2006, 09:57:06 PM »
Download a higher quality version of your manual from here:
http://www.cryscom.nb.ca/Documents.htm
« Last Edit: June 08, 2006, 10:06:19 PM by tintin »
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline csendker
« Reply #8 on: June 08, 2006, 10:05:52 PM »
Thanks!  My copy - downloaded - was kinda fuzzy and printed like crap.  These seem like they'll work out great.
