Author Topic: 1981 CB900F  (Read 1250 times)
Offline vozzy
1981 CB900F
« on: April 23, 2012, 05:00:27 PM »
1981 CB900F. Bought as a work bike. 22K miles. All original except paint. Sounds like cam chain(s) is rattling, plus there is popping in exhaust when reving. Think I need to sync carbs and adjust chains. What will cause the popping?
Offline nixonwylie9
Re: 1981 CB900F
« Reply #1 on: April 23, 2012, 07:44:16 PM »
I would check the ignition timing probably not firing right ;)
good luck
Offline nixonwylie9
Re: 1981 CB900F
« Reply #2 on: April 23, 2012, 07:45:13 PM »
and plugs and plug gap so on
Offline grcamna2
Re: 1981 CB900F
« Reply #3 on: April 23, 2012, 07:53:09 PM »
Have you cleared out the tank/carbs. yet. ?
Offline vozzy
Re: 1981 CB900F
« Reply #4 on: April 24, 2012, 05:09:33 AM »
I ran some Seafoam through tank. Need to change plugs out ASAP. Cheap insurance
Offline grcamna2
Re: 1981 CB900F
« Reply #5 on: April 24, 2012, 06:44:18 AM »
I recommend removing the carbs. and cleaning out All the passages and flushing out the tank to remove the fine sediment on the bottom of it that will clog you're small passages in the carbs.
Offline cb650
Re: 1981 CB900F
« Reply #6 on: April 24, 2012, 02:13:23 PM »
If you decide to upgrade the shocks I'll take the old ones off you.
Offline vozzy
Re: 1981 CB900F
« Reply #7 on: April 26, 2012, 04:06:55 AM »
Upgrade? They look pretty good stock. Reservoirs and everything!
Offline cb650
Re: 1981 CB900F
« Reply #8 on: April 26, 2012, 12:48:23 PM »
Yes upgrade.    I have plenty that "LOOK" good but perform like a turd. ;D
