Author Topic: Cam Tower Bolt Size  (Read 3205 times)
Offline Prospect
Cam Tower Bolt Size
« on: April 23, 2012, 06:36:56 PM »
Anybody know the size and length of the #4 bolt shown in the picture.  I'm trying to find a replacement and honda has it on backorder.  None of the books I have mention the size.  It's BOLT, SHAFT STOPPER part 90052-300-000
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline nayto550
Re: Cam Tower Bolt Size
« Reply #1 on: April 23, 2012, 07:11:22 PM »
63mm long, 5mm shaft, 16mm thread length... not sure about the thread pitch, I lost my gauge some time ago and haven't replaced it yet.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline Prospect
« Reply #2 on: April 24, 2012, 05:53:29 AM »
Thanks!   Ordered some from Brafasco delivered right to my door.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline crabbyjay
« Reply #3 on: May 16, 2012, 07:24:42 PM »
Did your replacement bolt fit, and if so what was the thread pitch?  I've got my original bolts but have stripped threads in the shaft so probably have to go the heli-coil route.
« Reply #4 on: May 16, 2012, 11:19:06 PM »
There is a fix for stripped threads using 1/4"-28 bolts.Some guys don't like sae bolts in their metric bike. Didn't bother me. Look in FAQ's
Offline markb
  • When I finish my current project I might be a
« Reply #5 on: May 17, 2012, 06:00:07 AM »
No, it's an M6 x 1.0.  The 63mm length is correct.  It also has a 10mm hex head.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Prospect
« Reply #6 on: May 17, 2012, 07:17:20 AM »
I contemplated going the 1/4" route but instead I put in six helicoils in there and was able to torque it down to spec.  Those stripped threads  gave me the greatest source of frustration next to figuring out crank-pin and crankshaft bearing colours.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline crabbyjay
« Reply #7 on: May 17, 2012, 01:39:46 PM »
I can get a 9 mm length helicoil with the right dimensions (M6x1.0). Would it be best to use two (cut one of these to achieve the correct thread depth of 16mm) or just use one insert?  I've not used helicoils before so I'm not sure.  Or is there another combination out there I haven't found yet that would be better?
Offline markb
« Reply #8 on: May 17, 2012, 03:31:38 PM »
Just use one.  The length of the insert doesn't have to match the length of the thread on the screw.
Offline Prospect
« Reply #9 on: May 17, 2012, 03:36:50 PM »
I just used one.  If you use two then you run the risk of misaligning the thread between the two (not ligning up) and then you're really screwed (pun intended).
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
« Reply #10 on: May 17, 2012, 05:01:41 PM »
I think they are hardened. That's why they carry a special part number and not a standard hardware part number. Wouldn't keep me from using standard hardware, as i have in the past. Just saying...
