Author Topic: Piston ring 101  (Read 9799 times)
blier74
Re: Piston ring 101
« Reply #25 on: April 12, 2008, 06:55:33 PM »
Just took my cylinders to the machine shop and was told to use a drop of WD40 on the piston skirt when re-installing, not copious amounts of oil, as it will lead to varnish and poor compression.
Re: Piston ring 101
« Reply #26 on: April 12, 2008, 11:27:26 PM »
Have not seen this mentioned on here..
For decades, I alwys put the gap on the top ring, 180 degrees from the midpoint between exh valve and sparkplug.
FWIW..
