Author Topic: lapping made leaks worse!?!?!  (Read 19027 times)
Offline grcamna2
Re: lapping made leaks worse!?!?!
« Reply #75 on: May 02, 2012, 09:32:24 PM »
well tomorrow ill be calling around trying to find a good machine shop or motorcycle shop to recut my seats and check out my valves lets hope it wont cost me an arm and a leg, and i really hope i dont need to buy new valves. but well see what comes up tomorrow. if any one knows a good shop around my neck of the woods, that would be great!
I know that a great Japanese motorcycle shop will either be able to do them..or will be able to steer you in the direction of a Shop that has done some quality work for them..from their own experience.I would personally want to have a trained eye give me a "heads up" on the condition of the valve guides and seats.I think you'll be glad when you take you're bike for a ride knowing that all the power that is being produced in the firing zones of your engine will be efficiently applied to the pistons downward thrust, rather than possibly leaking past your valve seats.
I like balanced compression numbers for a smooth running engine..and it'll last for a while w/o having to "rebuild it again next year", as some V twin guys love to do.
USCG_C130,
  You may have to do lot's of research to find the one your comfortable with before you hand it over to them...,I think you'll know it when you find it.  ;)
I sent mine out to a place in CO. this past Winter recommended from the sohc4 Guru that we all love so much here & I'm very pleased.  :)
75' CB400F/'bunch o' parts'
« Reply #76 on: May 02, 2012, 11:46:39 PM »
 I am going to point out, the manufacturers are assembling brand new stuff, in a high volume production setting, we are usually not..
Offline crazypj
  • I'm brill, me
« Reply #77 on: May 03, 2012, 09:50:44 AM »
The factories use 'interference angles when new, 45 on valve, 46 on seat.
sharp edge makes good seal and it 'hammers down' to match valve in a couple of hundred miles.
If you ever check valve clearance on a brand new bike, you'll find it's generally 0.002"~0.004" larger than recommended but quiets down within about 50 miles
« Reply #78 on: May 03, 2012, 09:57:04 AM »
 The fasctory is banging them out quickly
 We are sometimes "touching them up"
 If the factory left no room for improvement.we would all be riding stocker...( only partly true, manufactures have to abide by ewmission requiements and please the mASSes)
Offline crazypj
  • I'm brill, me
« Reply #79 on: May 03, 2012, 10:12:38 AM »
Yep, Honda were making a complete motorcycle in around 7 seconds back in the late 70's
It's pretty difficult to improve a new 1000cc 150+ bhp sport bike, without spending a LOT of money  ;)
Offline USCG_C130
« Reply #80 on: May 22, 2012, 10:56:12 AM »
Got an update. Today i dropped off my head to get the valves cut it was the only place i found to do it. But it is the same guy who honned my cylinders  he wanted  almost 300$!!!!!! And i talked him down to 180$ because he charges by the hour. He said hell do a 3 angle on them but its with a neway not serdi.. so i just went with it i called so many places and just want it done. I should have my head back in a week or so and ready to FINALLY get my motor back together. Wish me luck thanks for all your guys help.
Offline lucky
« Reply #81 on: May 22, 2012, 11:00:36 AM »
It is supposed to have 3 angles on them.
WATCH THIS.
THIS is how it is supposed to be done.
Honda CB750 cafe SOHC4 Neway Valve Seat cutting.AVI
Offline chewbacca5000
  • I polish covers!
« Reply #82 on: May 22, 2012, 11:27:11 AM »
I would go with the serdi if possible.  I have a guy where I leave who is reasonable and does a good job.  If you hunt around and try speed shops bet you could find a better deal.
