Author Topic: Leaking carbs cb400f, i need some tips please  (Read 2122 times)
Offline Mugen_Stumpo
« on: April 28, 2012, 05:39:59 AM »
Hi guys...
i'm trying to bring back to life my engine... everything should be ok but the carbs...
today i filled the tank, open the gas tap and gasoline came out of the carbs breather hoses like a waterfall...
what it could be? do the carb's float bowls are stuck?
if i just want to buy used carbs to rebuilt can i just buy cb400f carb or they are different from the f1 to the f2?
thanks a lot and sorry for my poor english :P
Offline Bodi
Re: Leaking carbs cb400f, i need some tips please
« Reply #1 on: April 28, 2012, 08:08:46 AM »
First, try tapping the bowls with fuel on, using the plastic handle of a screwdriver is good. If the float valves are just gummed up that might free them to seal.
If not: you will have to remove the carbs and their fuel bowls. This is a good idea regardless... if the float valves are gummed up there's probably lots more crud in there.
Just removing and cleaning the float valves usually brings them back. If they have brass needles, you can lap them into their seats with a spot of brasso, a but of plastic tube or wire insulation can be used to hold the needle and turn it in the seat. Rubber tip needles, or really corroded seats or metal needles need to be replaced. Use Honda OEM parts. Honda sells float valves and gasket kits, they cost more than aftermarket "carb kits" but they're genuine Keihin parts and worth it.
You should also clean out all the jets, emulsion tube holes (on pilot jet and the main emulsion tube), internal carb passages, and the bowl and carb inside. Be careful removing the float valve pins: they get corroded in, and using much force will break off the support post which is a pretty nasty thing to fix.
There are lots of forum posts on these jobs. Check in the "tips and tricks" topic.
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: April 28, 2012, 12:33:34 PM »
+1
A couple taps with a screwdriver usually works for me.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #3 on: April 28, 2012, 01:03:48 PM »
thanks... i'll try that ;D
