Author Topic: Crank Bearings  (Read 773 times)
Offline wingingit2
Crank Bearings
« on: April 28, 2012, 06:23:17 PM »
A Newbie here,
Can someone tell me if my 79' CB750 has plane or ball bearing, or roller bearings in the crankshaft? I have a bad growling from the right side. Looking at the Parts Fiche I can't really tell. It would be nice to know ahead of tear down time what I'm getting into. I've split plenty of cases, not 750's though.
I have a few manuals to share if there is a place to upload them here.
Thanks
Glenn
Lady Luck Prefers the Prepared
Offline cbr954
Re: Crank Bearings
« Reply #1 on: April 28, 2012, 06:27:23 PM »
Crankshaft is all plane bearings, transmission uses ball bearings.  Right side of engine I would check into the clutch.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline Bodi
Re: Crank Bearings
« Reply #2 on: April 29, 2012, 05:54:47 AM »
Growling noise, huh?
The crank is all plain bearings. Failed crank bearings sound more like a jackhammer has gotten in the engine.
The primary shaft drives the clutch by gear, and I've had an engine with bad gear end bearings on the primary shaft that definitely "growled".
Re: Crank Bearings
« Reply #3 on: April 29, 2012, 11:44:24 AM »
Keep your speed constant but put it in different gears. Noise cahnges with different gears = tranny maybe?
Offline wingingit2
Re: Crank Bearings
« Reply #4 on: April 29, 2012, 12:20:13 PM »
Thanks Guy's.
 It is hard to tell if it from the crank or clutch. It sounds like a bad ball bearing as opposed to a rod knock (plain bearings).
If I can sell 2 project bikes I have I will be getting into the 750 soon.
