Author Topic: Who has Keihin CR parts? slides needed  (Read 6245 times)
Offline brandEn
« on: April 28, 2012, 07:31:52 PM »
mods: I am posting this here cuz most of the hi-po guys never make it to the wanted section. I apologize in advance if it must be moved.
After taking my bike on the Dyno today it appears I need some leaner "throttle valves" (slides) for my CR29's. Our friends at Sudco want almost $200 for a set of these suckers and I am just not paying that much. Any chance someone here has a set of size 3.0mm carb slides? I can swap you for my like new 2.5 slides or just buy them. CR 26-33's all use the same slide part numbers. Any help appreciated.
Keihin part # 018-642
item #22
Offline turboguzzi
Re: Who has Keihin CR parts? slides needed
« Reply #1 on: April 28, 2012, 11:18:25 PM »
cant help you with slides
but from my experience, CR are highly adaptive through just main jets, needle height and idel mixture screw. thats all i needed to touch and my 29 have already moved three bikes with 500, 600 & 810 cc... you have also the simple option of changing the external air jet in the front (never needed to touch it)
are you sure your dyno guy knows slide carbs? most of them nowadayswork only on injected bikes and are usually quite surprised that you cnat wack the throttle open on slide carbs without the engine bogging
Offline Darvill Racing
    • Darvill Racing
« Reply #2 on: April 28, 2012, 11:30:17 PM »
I also have a question:
Are all the float bowls the same size...?
I won't bore you with the reason but looking through the parts manual they all seem to have the same part number.
Regards,
A
Best Regards,
Alex
Darvill Racing
Offline brandEn
« Reply #3 on: April 28, 2012, 11:36:26 PM »
Regards,
A
Yes, bowls are the same size.
Offline brandEn
« Reply #4 on: April 28, 2012, 11:38:00 PM »
Yes, my tuner is our own Doctor_D. We messed around with everything and she just runs rich down low.
« Reply #5 on: April 29, 2012, 04:16:19 AM »
Ah, good ol' CR carbs, great on WOT race applications, but I wonder how many owners have blown their brains out after spending a weekend trying to get them to work properly on a road bike?
I've got a set of new 31mm CR's in a box, and a set of 33mm Mikuni smoothbores as well. After the drama's I had with the 29mm CR's on my K1, I think I'll use the Mikuni's on my 1060cc build. Cheers, Terry. ;D
Offline turboguzzi
« Reply #6 on: April 29, 2012, 07:09:32 AM »
+1, and yes, i know there are people who have managed to make them work on the street, but why bother for a few extra hp at redline?
if you are 200% sure you need bigger slide cutout, you could always grind them, though there's no way back....
Offline Doctor_D
« Reply #7 on: April 29, 2012, 08:38:55 AM »
CR's are some of the most intuitive and easiest to tune carbs made.  Now, if we were talking Amal GP's - I'd understand the carping.  Those carbs are most definitely not for street use.
The issue he's having is that 1/8 to 1/4 throttle, steady state, Branden is running about 11.5:1 A/F.  He has very good vacuum at low rpm's, unlike higher strung motors. The rich slide cutaway was supposed to help compensate for the lack of vacuum signal.  It's a simple, albeit pricey, fix.
Sure, I can tune that out with the needle and air screw, but then we're left with a huge lean-out condition on throttle opening.
Branden, we'll raid my CR31's.  You'll be fine.
Take care,
David
1978 CX500
1971 Norton Commando
« Reply #8 on: April 29, 2012, 09:13:55 AM »
I have to agree with David. I ran them for over 20 years. They certainly have their issues (cold start system sucks) but they are pretty easy to work with.
« Last Edit: April 29, 2012, 09:22:13 AM by MRieck »
Offline turboguzzi
« Reply #9 on: April 29, 2012, 01:32:20 PM »
mike, dave
didnt mean they are hard to work with, just that they wouldnt be my choice in a street bike where you might want to be able to cruise in 5th with a whiff of throttle or idle at a stop light for a few minutes, think that's also what terry meant.
they work great on my road racers and are easy indeed to tune for that kind of application, but to say that i can get from them consistent idling? not realy, there must be a reason why so many people fit to CR's remote idle screw adjusters.... ;)
« Last Edit: April 29, 2012, 01:34:16 PM by turboguzzi »
« Reply #10 on: April 29, 2012, 05:39:34 PM »
Hi Branden, Give Forum member Ilbikes a pm, he has a very sweet running 836 with CR's, he's a very knowledgeable guy...
http://forums.sohc4.net/index.php?action=profile;u=2968
Offline brandEn
« Reply #11 on: April 29, 2012, 05:58:46 PM »
Thanks Mick, My bike runs great as well but we are just fine tuning it. David has me covered.
Offline bochnak
    • How-To Motorcycle Repair Blog
« Reply #12 on: January 18, 2013, 10:38:31 AM »
I'm trying to tune the same carbs, CR26, and have noticed what I believe to be a rich spot right around 3k RPM and 1/8 throttle setting.
I'm running 65 pilots, YY8 needles - 7P, 1.5 turn out air screw, to give you an idea of 0-1/2 jetting.
I have tried 60 pilots and 3P through 7P on needle clip and the problem persists, so I'm thinking it's the slides. 2.0's are currently installed.
