Author Topic: Engine Braking - 76 vs. 77-78  (Read 1583 times)
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« on: April 30, 2012, 02:32:10 PM »
Has anybody ridden, or have experience with the 76 models versus the 77-78 models, and engine braking?
I'm asking because the idle speed solenoid on the 76 is energized all the time the bike is in gear, while the 77-78 models have the solenoid energized only when the speed is lower than 20 MPH (or so).  I would expect that the 77-78 models have more engine braking when rolling off of the throttle at speeds higher than 20 MPH - but how much, and is the difference even worth the thought/worry?
I'm also asking because my long term plan is to replace the stock speedometer with an aftermarket electronic unit, and I'll be losing the 20 MPH speed switch - and going to the 76 wiring/control.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
