Author Topic: Pressed in slow jets  (Read 1075 times)
rebel4089
« on: June 09, 2006, 09:14:03 PM »
What would be the best way to pull pressed in jets out to clean?  Or should I clean them in the carbs?  Also I've been hearing changing the exhaust should not require a jet change, is that true?  What kind of mods can I do to my 1980 CB650 Custom?
Offline mick750F
Re: Pressed in slow jets
« Reply #1 on: June 09, 2006, 10:21:25 PM »
   As far as the jets go I'll reach into the way back machine and give you this as it's a little late to type it all out again....
131     Main Boards / Tech Forum / Re: Keihin Carburetors    on: November 15, 2005, 07:56:20 PM
   I just removed the slow jets on mine. They came out easily with a piece of leather and slip-joint pliers. I wrapped the leather around the jet to protect it and then gently twisted with the pliers to loosen it a little. Then I gently pulled straight up. I was actually surprised at how easily they came out after reading Honda's warning in the shop manual. "The slow jet must not be removed since it is a press in fit."  Yeah...right.
Mike
   Changing the exhaust may or may not require a jet change. It depends on what the exhaust is. Mods to a 650? The sky and ebay are your limit. I for one don't really know what's available as far as after market for 650s. Good luck...
Mike
Glosta, MA
Offline scunny
  • don't call me expert
« Reply #2 on: June 09, 2006, 10:33:51 PM »
After much searching I have come to the conclusion that there aren't a lot of "aftermarket mods"  available for the 650, possibly because there was no racing class for it. A firm in Canada offer a modification for the cam which I'm led to believe alters the duration of valve lift. Apart from a more efficient exhaust and carb filter setup, that's as far as mine will be going for a start.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
