Author Topic: how to remove tires from wheels?  (Read 6668 times)
Offline lucky
Re: how to remove tires from wheels?
« Reply #25 on: May 03, 2012, 11:36:33 AM »
Thanks guys looks like I'll do whatever I can to get these old crusty tires off so I can work on the wheels. When I get new tires I'll have them mounted and balanced at a tire shop! I'll be replacing the tubes and everything anyways. Not sure you get the idea just HOW crusty these tires are LOL
Go online and watch some motorcycle tire changing videos!!!
You have one of the most powerful tools in the WORLD. The computer.
There is no excuse !! -LUCKY
BTW...Do not attempt to cut the tire off. You can get seriously hurt trying to cut the steel reinforced tire. And damage the rim . Of course if you get hurt you will not care about the rim. LOL.
Offline lucky
« Reply #26 on: May 03, 2012, 11:42:14 AM »
Age has nothing to do with anything. I just find it funny that so much can be said about removing a tyre. I could do this task when I was around 6, nearly 8 years ago now.  :P
I understand LesterPiglet, most of us had to change our own bicycle tires with tubes .
Many kids grow up now and just take everything to the bicycle shop.
Where I grew up we did not have the money for that.
Offline lucky
« Reply #27 on: May 03, 2012, 11:43:31 AM »
Old tires get hard and they are a #$%* to get off. I have cut them off and that is fine. You will need some irons to put the new tires on and not put a hole in the tube. Soapy water or Windex is a good lube to mounting tires.
Old tires get hard but if you know how they will come right off.-LUCKY
THIS IS A GOOD VIDEO !!
Motocross Tire Change. Jay Clark and Dunlop Tires.
« Last Edit: May 03, 2012, 11:57:57 AM by lucky »
Offline lucky
« Reply #28 on: May 03, 2012, 11:44:54 AM »
Just took mine off both front and back so i could put new spokes on. Just used a utility knife to cut away down to the inner cable and then cut those with a dremel. The crustier the easier to cut with a utitlity knife....my forearm got a good workout:) Think I read elsewhere some people used a sawsawl
So much work and risk when you could just learn to do it the easy way. The right way.
Offline bert96
  • past ride
« Reply #29 on: May 03, 2012, 12:10:54 PM »
Bert- I wanted to watch the youtube...but I got stuck on your avatar.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline mono
  • Definitely no
« Reply #30 on: May 03, 2012, 12:16:47 PM »
probably my favorite thread ever - both informative AND funny.  :)
that trick in the vid is seriously cool.
Offline CycleRanger
  • No comment about being an
« Reply #31 on: May 03, 2012, 12:28:12 PM »
Good grief.
Why don't you just tell him not to ride the bike either, he could get seriously hurt..... And damage the bike.  ::)
« Reply #32 on: May 03, 2012, 03:32:24 PM »
[/quote]
[/quote]
Oh Poo. Just use a hacksaw straight down the middle and a tin snips when you get to the bead. If you wet the rubber it cuts easier.
Offline socalenduro
« Reply #33 on: May 03, 2012, 03:46:23 PM »
+1 on windex
dont try to do it in the cold
if your bike lives in the garage take them inside or leave them in the sun for a bit
« Reply #34 on: May 03, 2012, 08:38:18 PM »
 I suppose you can get hurt EVEN WORSE, cutting the bead..IF ..the bike has no aircleaner or STACKS...
Offline BeSeeingYou
« Reply #35 on: May 03, 2012, 09:35:17 PM »
I often read this about old tires being "hard" but I had no problem taking off a 20 year old tire and two others in their 30's recently.  Just used three irons and the rim resting on a small garbage can.  It was no big deal and was as 754 said in an earlier post easier and quicker than cutting it off which I had also done.
« Last Edit: May 03, 2012, 10:03:33 PM by srust58 »
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #36 on: May 04, 2012, 10:27:04 AM »
Oh yeah! Some snips would've done the trick. Oh well, it was an old #$%*ty rim and all I needed was a couple of spokes. BTW: '74 CB750K hub/speedo drive for sale! :)
Offline lucky
« Reply #37 on: May 04, 2012, 02:56:24 PM »
Good grief.
YEah...I hate when they damage the bike!!!  LOL///lol/lol
Offline killersoundz
« Reply #38 on: May 06, 2012, 01:11:38 PM »
I got the front tire off by cutting it off, sliced it down the middle with a razor and then snipped the steel bands on either side. I was trying to do the same thing with the rear wheel but I ended up trying a hacksaw for the steel bands and sliced into the wheel LOL  :'(   There's a 1/4" deep gash in the side of my wheel now. Do I need to replace the wheel or do you think I can get my uncle to fill it in with some mig weld and sand it smooth?
« Last Edit: May 06, 2012, 01:44:48 PM by killersoundz »
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
« Reply #39 on: May 06, 2012, 01:13:55 PM »
For the record, this would have NEVER happened with the tires that were on my bike. They have steel bands around the insides and they are stiff as hell, they won't stretch at all there is no way to lift them over the wheel I don't care what tools you have
My project thread:
« Reply #40 on: May 06, 2012, 03:38:17 PM »
 They never do stretch coming off, you MUST position bead into INNERMOST portion of rim..ie, the middle, then start lifting over edge of rim on OPPOSITE side..
 Failure to do this means... you aint getting it off..
Offline BeSeeingYou
« Reply #41 on: May 06, 2012, 04:24:21 PM »
Yeah, I forgot to mention I used two of those woodworkers clamps to pinch the bead together on the opposite side.  Large C clamps would work too.  I have two 6 inch irons and a 24 inch.  The small ones have nice slim ends but lack leverage so when I need them on the initial bead lift I just slipped a short piece of pipe over the end of the iron to gain leverage.
« Last Edit: May 06, 2012, 04:30:12 PM by srust58 »
