Author Topic: Might be putting a new exhuast on my bike  (Read 1136 times)
Offline redrider1957
« on: May 04, 2012, 03:28:39 PM »
I currently have a 1977 CB750 with Dual 2 into 1 exhaust pipes. The pipes have no baffles in them and the jetting is absolutely perfect. My question is I recently bought a 4-into-1 MAC exhaust for $50 and would like to put it on my bike, the issue is that it has the baffle in it currently and would like to leave it there if possible. Could I just drill a bunch of holes and it should be good or do I need to remove the baffle to get it to run properly?
Thanks in advance.
Offline nayto550
Re: Might be putting a new exhuast on my bike
« Reply #1 on: May 04, 2012, 03:34:01 PM »
I would try the pipe as is first.  Then if there is a runability issue, start the process of rejetting the carbs.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
« Reply #2 on: May 04, 2012, 05:35:56 PM »
Does anyone have any idea how loud it would be without the baffle? Is that even a good option or do I run the risk of hurting valve if I leave it wide open?
Offline derelicte
  • '74 CB750
« Reply #3 on: May 04, 2012, 05:39:17 PM »
absurdly loud.  i bought a 750 that came with a mac 4 into 1 with no baffle, its headache loud.  if you dont run the baffle, ill buy it from you (seriously, ive been watching for one on ebay lol)
Offline GammaFlat
« Reply #4 on: May 05, 2012, 10:50:03 AM »
I had a MAC 4-1 on my K6 and without the baffle it was obnoxious.  I tend to like less noise rather than more but I'm betting a lot of law enforcement would "encourage" you (give you tickets) to put the baffle back in.  I have heard of folks modifying the baffle to try to make the MAC more throaty.  I'm not sure if the threads are still around where folks were doing that.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline Guns_Up
« Reply #5 on: May 05, 2012, 11:06:08 AM »
I am looking at a set, there are after market but it doesn't look like they will use the stock collar, will they use clamps? Or how do i go about mounting these. Can someone enlighten me on this subject please
« Reply #6 on: May 05, 2012, 04:09:06 PM »
check the MAC website...they offer two baffles, the race baffle sounds nice, kinda quiet at idle but has a voice at high rpm, the regular baffle is just quiet, I tried to drill more holes/modify mine and my bike ran like crap, pulled it out and it was even worse, then removed the whole muffler, just an open header and it ran pretty good :-\...still don't understand this
