Author Topic: CB750K6 brake problem  (Read 919 times)
Offline PhilWall
« on: May 05, 2012, 09:54:17 AM »
Hi.  I'm looking for help.  I'm just in the final stages of rebuilding my K6.  The original had been converted to 2 discs with flexible hoses all the way to the brake calipers.  I've bought a Honda brake hose kit but when I screw the metal pipe section all the way home into the caliper, the pipe is still lose - I can move it up and down about 1mm.  The drawings on cmsnl.com don't show any other seals etc.. between the pipe and the caliper. Any ideas much appreciated.  Thanks, Phil
Re: CB750K6 brake problem
« Reply #1 on: May 05, 2012, 10:21:24 AM »
The pressed-in steel seat for the flare fitting may have been removed from the caliper.
« Reply #2 on: May 05, 2012, 10:22:26 AM »
Oops, wrong pic...
Offline PhilWall
« Reply #3 on: May 05, 2012, 10:24:26 AM »
Yes, I just checked and that is missing (from both calipers). Do you know where I can get new inserts?
« Reply #4 on: May 05, 2012, 10:46:31 AM »
Sorry, I don't think they are available separately. Maybe you can find one that someone has removed to fit different style fittings. (I would be willing to give you mine, but think it would cost more than a 50 cent stamp to mail it to you.)
By the way, welcome to the forums!!!
Offline PhilWall
« Reply #5 on: May 05, 2012, 12:24:17 PM »
firstly sorry for the delayed reply . I have had to leave the house and am using my daughters phone. I would be so grateful if I could buy your one and would obviously pay you the full postage and something for the insert.e i will be going into the cinema shortly so will not be auble to reply until tomorrow but thanks so much for your help so far!
