Author Topic: 76 750f motor  (Read 927 times)
Offline bikerbart
76 750f motor
« on: May 05, 2012, 12:05:12 pm »
So,My spare motor is no.2521601,am I correct in the year?And can I use my 72K carbs (bigger slow jets and main,say 120??).I have both pods and airbox,this is going to be for my rat bar hopper,so looks is a plus(pods)These are the only carbs I have at the moment,and I would like to use em if they'll work??
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
Re: 76 750f motor
« Reply #1 on: May 05, 2012, 01:35:19 pm »
If it helps, my '76 f1 was built in June '75 and the engine is: 2532962
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline bikerbart
Re: 76 750f motor
« Reply #2 on: May 05, 2012, 02:09:48 pm »
thanks
Offline david 750f
  • 1976 CB750F
Re: 76 750f motor
« Reply #3 on: May 05, 2012, 02:13:56 pm »
Looks like you have a early 1976 F motor. The 1976 F serial numbers start at 2515094.
There should also be a 392 number cast into the cylinder head.
1976 CB 750F
Offline BeSeeingYou
Re: 76 750f motor
« Reply #4 on: May 05, 2012, 02:48:38 pm »
The carbs should fit whether it's an F or a K motor.
Offline bikerbart
Re: 76 750f motor
« Reply #5 on: May 06, 2012, 08:38:31 am »
fit ,yes I know that.I wanted to know if the F carbs are different for that year,I had a 77 750 F and I know those are different.
Offline CycleRanger
  • No comment about being an
Re: 76 750f motor
« Reply #6 on: May 06, 2012, 09:11:16 am »
The carbs are the same, only the jets differ.
Re: 76 750f motor
« Reply #7 on: May 06, 2012, 10:01:26 am »
Including the needle and needle jet, not to say you can't make it work though, but the mains and clip positions are an easy do.
Offline bikerbart
Re: 76 750f motor
« Reply #8 on: May 06, 2012, 07:40:14 pm »
Thanks Jerry
