Author Topic: Exhaust Wrap  (Read 5445 times)
Offline Magilla
  • My bike: 1976 CB750F
Exhaust Wrap
« on: May 07, 2012, 08:28:31 AM »
I am planning to wrap my exhaust (front half back to mufflers).  How much (feet) do I need?  Any tips?  How do you mount it?  What stops it form unraveling?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Elan
    • Vital Motor Parts
Re: Exhaust Wrap
« Reply #1 on: May 07, 2012, 08:30:42 AM »
you need to tell us what bike ou have, and what type of exhaust you have. 4 into 1? 4 into 4? 2into 1?
76 750k
Offline Magilla
Re: Exhaust Wrap
« Reply #2 on: May 07, 2012, 09:04:53 AM »
Good Point!!  1976 Honda CB750.  Factory 4 into 4 exhaust.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Re: Exhaust Wrap
« Reply #3 on: May 07, 2012, 09:07:33 AM »
wear gloves. wet it.  wrap it tight.
start and finish it with aircraft wire or stainless zip ties to start (@Headers) and finish (@ exhaust).
Offline Elan
    • Vital Motor Parts
Re: Exhaust Wrap
« Reply #4 on: May 07, 2012, 09:13:58 AM »
I just did my 4 into 1 on my 750, and bought a 50'x2" roll and have probably 10 feet left.  I started at the base and went up toward the headers. This way its layered the same directions as shingles or siding. wrap usually comes with ties, but the ones I got suck, ill probably switch to regular bands that tightn with a screwdriver.
76 750k
Offline Eddie
Re: Exhaust Wrap
« Reply #5 on: May 07, 2012, 12:54:54 PM »
or you can use ech Flex...good to 1200deg...no wrapping..no clamps.
www.techflex.com
Offline aperry
Re: Exhaust Wrap
« Reply #6 on: May 07, 2012, 01:03:26 PM »
I just did this with a 750 4-1 header.  I used 2" wrap and had 100' of it, of which I probably only used 50-60'.  The bike build is still in progress, so I can't comment on how it stands up to riding.
Quick question:  Even though I have mine double-tied on both sides of each wrap, I still worry a little about fraying.  Is it common to use some kind of high-temp glue (or something?) to seal the ends of the wrap to prevent any possibility of fraying?  I think the stainless steel ties should (in theory) prevent fraying, but I'd feel more comfortable if I were able to seal the ends.  The wrap I used seemed to come undone quite easily once you cut it.
Thanks,
Aaron
CB750K3 with F1 frame/swingarm
Offline Magilla
Re: Exhaust Wrap
« Reply #7 on: May 15, 2012, 03:47:55 AM »
Wow was that a messy job.  I was not able to wear gloves because I could not feel and pull the wrap correctly.  Two days later my fingernails are still black.  I have the stainless wire ties in place but I am wondering if hose clamps would be more efficient for reducing fray on the muffler side of the wrap.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Exhaust Wrap
« Reply #8 on: May 15, 2012, 04:52:42 AM »
I make a little "cap" for the ends by bending thin aluminum into a V shape and then crimping down on the wrap.  Stainless, or brass (vintage cool) aircraft safety wire wrapped and tightened in two places will keep it snug.  Sorry no pics, too busy actually building ....... :-)
Offline socalenduro
Re: Exhaust Wrap
« Reply #9 on: May 16, 2012, 01:53:00 PM »
bit of a hijack but ill do it anyway
my bike leaks oil... a bit more than most....
ive heard that wrap allows it to collect and possibly ignite..
but my muffler is already soaked in caked on oil most of the time and ive never even seen it smoke....
thoughts?
