Author Topic: removing the trans gears off the shafts??? one more question  (Read 1887 times)
Offline garretcb750
can anyone tell me if its critical for the trans gears that are splined to the shaft to be clocked in a particualar position??
starting to put my motor together and I'm paranoid.
« Last Edit: May 08, 2012, 01:22:29 PM by garretcb750 »
Offline bear
  • Leeton in Australia
Re: removing the trans gears off the shafts???
« Reply #1 on: May 07, 2012, 04:42:49 PM »
No
But if it worries you then do it, it won't hurt.
Brian
Offline garretcb750
« Reply #2 on: May 07, 2012, 07:01:00 PM »
ok... perfect   thanks bear.
ps that goes for both shafts right? i was worried about some gears not meshing.
Offline bear
« Reply #3 on: May 08, 2012, 05:17:03 AM »
Yep both shafts.
Brian
« Last Edit: May 08, 2012, 05:31:27 AM by bear »
« Reply #4 on: May 08, 2012, 07:53:44 AM »
 Garret unless gearsare in multples of toothcount, the position is everchanging.
Offline garretcb750
« Reply #5 on: May 08, 2012, 01:19:26 PM »
ok thats great.. also... there is an oil hole on some gear bushings...should it be lined up with the oil hole on shaft?
or should it force the oil around the inside of the bushing and out to the gear.
Re: removing the trans gears off the shafts??? one more question
« Reply #6 on: May 08, 2012, 07:18:36 PM »
 If it has a bushing it probably freewheels til the shifter fork sildes it over and engages it, THEN it stops turning...
Offline garretcb750
« Reply #7 on: May 08, 2012, 08:10:26 PM »
so not a big deal? no major stress on the gear until its engaged into another gear... makes sense.  thanks 754
« Reply #8 on: May 08, 2012, 10:17:22 PM »
Make sure you install the snap-rings that locate the gears on the shaft correctly; there is a rounded edge on one side of the ring, and a sharp edge on the other. The rounded side should go against the gear. If they are reversed, the rings can be forced out of their grooves, and allow the gears to slide freely on the shaft, engaging a gear even with the shifter in neutral. It happened to me: the bike moved forward, folding the side-stand and falling over on me, when cranking the motor over with the electric starter during a compression test.
« Reply #9 on: May 08, 2012, 11:04:08 PM »
just out of interest some heavy truck gearboxes have gears with index marks on them for assembly a bit like timing marks,this keeps the teeth meshed as they were when new.
Offline trueblue
« Reply #10 on: May 09, 2012, 04:34:20 AM »
The Eaton Roadranger boxes are like this, the reasoning for this is as they turn if they aren't timed correctly the gears will try to climb over each other, they are basically 2 gearboxes in one, they have 2 sets of 3 shafts.  As they bind up it forces the shafts apart and they will actually crack the casings open, I have seen this happen, it's not pretty.
« Last Edit: May 09, 2012, 04:36:49 AM by trueblue »
1979 CB650Z
