Author Topic: ATF + Acetone  (Read 2198 times)
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
ATF + Acetone
« on: May 08, 2012, 09:41:33 AM »
A buddy of mine inherited a WWII era Walther Olympia pistol that was seized up due to surface rust on the mating surfaces of the slide to frame and the magazine release.  I figured if ATF and Acetone is good for a seized engine, it should work on a gun too.  Soaked the whole gun in a coffee can over night.  Worked like a charm, my buddy thinks I'm a genius now (didn't tell him I learned it on this forum) ;)
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Re: ATF + Acetone
« Reply #1 on: May 08, 2012, 09:47:42 AM »
Here is an interesting info too:
Some of you might appreciate this. Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts.
They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ......... 127 pounds
Kano Kroil .............. 106 pounds
ATF-Acetone mix.......53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
It floats around the 'net for a while.
Offline jamesb
Re: ATF + Acetone
« Reply #2 on: May 08, 2012, 10:11:04 AM »
interesting! now can you spray the mix on a rusted nut and bolt like you would with any other penetrating oil. my 1960 Bel air is having some issues that i need to attend and I'm wanting to try this.
Re: ATF + Acetone
« Reply #3 on: May 08, 2012, 10:53:14 AM »
You can use an aerosol sprayer, like this:
http://www.google.com/products/catalog?q=aerosol+sprayer&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=15690818378914079142&sa=X&ei=UlypT7asAcmoiALIzMTTAg&ved=0CLYBEPMCMAA
This was just the first hit from a google search.  I'm sure there are other to be found.
The only worry might be the plastic container melting with the acetone.  But usually, if it is ok for non-latex paint, it is ok with acetone.
Offline ChuckG750f1
Re: ATF + Acetone
« Reply #4 on: May 08, 2012, 01:22:13 PM »
That's fantastic.  Thanks for posting it.
- John Wayne
1976 CB750 f1
Offline pangloss
  • CB500 K2 1975 NZ model
Re: ATF + Acetone
« Reply #5 on: May 08, 2012, 02:22:09 PM »
Any good brews like this for soaking Honda gasket bond off. Getting the original gasket surfaces clear is pretty tough
