Author Topic: Gas leaking out left carb??  (Read 4706 times)
Offline messeduptriple
Re: Gas leaking out left carb??
« Reply #25 on: May 10, 2012, 07:46:39 PM »
I was told to feel the exhaust.... are they all hot... the far right header was cold... was told to look at the jets..maybe something is clogged
Sent from my MB855 using Tapatalk 2
« Reply #26 on: May 10, 2012, 07:48:08 PM »
From that ref guide i replaced the main jets left the others alone ...but they were cleaned out ...i did them..one was clogged...i cleaned it
Offline Flying J
« Reply #27 on: May 10, 2012, 10:04:00 PM »
Its Not only jets that need to be cleaned. The passageways as well as the emulsion tubes. I thought all my carbs were clean until i punched out the emulsion tubes and this one was not the worst of the 4.
« Reply #28 on: May 11, 2012, 01:59:30 AM »
I took the carbs out, the left and the right were clogged... i put them back in the bike.... i absolutely  hate pulling  carbs!
Anyways, im going to bed ...in the morning ill fire it up and see what  happens.
« Reply #29 on: May 11, 2012, 07:44:51 AM »
Lil pissed off....its still smoking, the rpms are really high and it dies when  i give it gas. I noticed it was leaking gas out the  right side of carb now. Im just upset now... that was a #$%* to take out and now put in... now i pull them  back out?
Offline Flying J
« Reply #30 on: May 11, 2012, 08:45:53 AM »
Don't do it half ass or you will be pulling the carbs again. Clean everything. Then clean all the holes in the actual carbs. If you can, punch out the emulsion tubes and clean them. Set the float height and make sure none of your overflow tubes are cracked. Then bench sync them. Also your bike will never idle right until you sync the carbs.
Offline thrutheframe
« Reply #31 on: May 12, 2012, 08:08:30 AM »
I agree with FFJ, you have them off, do EVERYTHING you can.  This is a game of patience and details.  You have a great start on a really nice machine, Your aesthetics are solid so far but think about this as priority list.
1 Safety
2 Reliability
3 Appearance
We all really want to see you succeed!
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Re: Re: Gas leaking out left carb??
« Reply #32 on: May 19, 2012, 11:30:51 AM »
1 Safety
2 Reliability
3 Appearance
the floats were adjusted but now the bike starts and runs good...only problem now is when I give it gas the bike wants to  putt out a bit
.then seems to catch and then have the power...seems to do this on 4th gear as well..what's going on now? .
Offline Flying J
« Reply #33 on: May 19, 2012, 11:46:43 AM »
Could be a million things. Have you synced the carbs? Until you have diagnosing issues is almost pointless.
« Reply #34 on: May 19, 2012, 12:38:19 PM »
gotcha
